AH FabricationsVolks Autos
Results 1 to 17 of 17
    dan77's Avatar
    dan77
    Dec 2008
    Down south,
    195
    Could this be a thermostat problem
    hi all i was driving down the motorway the other day when i noticed my engine temp had dropped about 10 degrees, i kept an eye on it for the rest of the journey and it kept goin up and down really slowly, this makes my limited little brain think it might be the thermostat reacting slowly, does this sound right to any1, or am i talking out my arse and should i get a garage to have a look!? any ideas would be appreciated
    A3 1.8T sport, revo stage 1, Forge 007, Green cotton panel filter, TTpedals. . . . . SOLD
    Golf GTTDI 130 . . . . . SOLD
    Current 2006 A3 2.0TDI Quattro S-Line, Revo stage one, chrome pedals, black grill, full interior and number plate LEDs retro fitted cruise control,
    Mr.G's Avatar
    Nov 2008
    In a Tardis!!
    1,302
    When my Thermostat was faulty it threw a fault in Vagcom.
    I'd get it to the garage to looksi, can't be a bad thing even just to check it over. Was it cold on the morning in question??
    G
    ash_pearce's Avatar
    Feb 2009
    Leicester
    319
    there is another thread on here somewhere about thermostats, generally it seems most people's stay around 90 degrees, however if your on the motorway the airflow is greater through the radiator which would lower the temp a bit. To be honest until the temp goes the other way I personally wouldn't worry too much.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,578
    Prior to me changing the cam belt and water pump over christmas, mine always stayed at 90 deg.... since then its sat at 80 deg occasionally creeping to 90 deg but would then go back down to 80 deg again.
    I am going to change my thermostat in the next week or so, I'll post the results here....
    For the record I have already changed the temp sender (green top)
    <tuffty/>
    dan77's Avatar
    dan77
    Dec 2008
    Down south,
    195
    thanks guys, its booked in for a cambelt change and service next week do you think its worth gettin the thermostat done then?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,578
    prob wouldn't hurt... the part is about 15 from Audi but not sure what they would charge to fit, you may be able to negotiate a good price as they will have most of the car apart for the cam belt
    Yaz
    Yaz's Avatar
    Oct 2008
    Essex
    225
    Quote Originally Posted by dan77 View Post
    I would mate, if you're changing the cambelt then you should also change the water pump and in turn the coolant, so it would make sense to change the thermostat at this time...
    1994 Audi 100 Avant 2.5TDI
    1987 VW Scirocco Scala
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Yep, get it all done at the same time, they going to have the front end off anyway, so might as well.
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Hello,
    First post here so hi!..... I'll do an introduction very shortly.
    My A3 had the same problem, the temp guage was up and down and wouldnt hold at a constant reading. After a bit of digging I worked out it was the temp sender unit, cost about 12 to change and sorted the problem out straight away.
    My guage would go up as normal and then drop off down, then come back up again. Its an easy fix and wont cost too much. Took about 10 minutes all in to sort out.
    Tom
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,280
    Your temp should stick at 90 no matter what the temp/weather is like outside. I changed mine in January and it always stays at 90 even over that cold period we had with all the snow and -8 temps.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    Mine is normally around 90 but drops slightly lower if on the motorway etc
    Is the temp sender the cause of lunpy idle sometimes too?
    AUTOMAP
    Mobile ECU Remapping Services
    automap.remapping@gmail.com
    www.eliteremaps.com
    wibble111's Avatar
    needs to scratch the itch
    Nov 2006
    derbyshire
    829
    Does anyone know if a dodgy temp sender will log a fault with vag-com?
    Westy's Avatar
    Dec 2008
    17,280
    Not sure about that Ian as I haven't had an issue with my temp sender....... yet!
    If your temp is dropping slightly on the motorway then the thermostat is starting to wear, its just a spring loaded valve. The spring just wears out of the years.
    S3 Build Thread
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Mine didnt cause a lumpy idle, it ran as it always does but the guage was a bit part time. It would warm up as usual and then drop to 10c or lower, then pop back up and then back down again. The stat was OK as the fans were kicking in etc when the car was stationary in traffic etc.
    When the weathers cold my car (once warmed up) will always run at 90c.
    enda1's Avatar
    Jan 2006
    Ireland
    439
    Quote Originally Posted by wibble111 View Post
    The higher tuned 1.8T engine in the likes of the S3 have a sensor on the thermostat and will show a fault. The normal engine has a standard thermostat
    Enda1
    96 S6 2.3T
    99 A6 1.8T SE
    93 80 2.0 (gone)
    93 Kawasaki ZZR600
    Westy's Avatar
    Dec 2008
    17,280
    Quote Originally Posted by enda1 View Post
    The temp sender will throw a fault but not the thermostat. The thermostat is just a spring loaded valve that opens under pressure from the cooling system.
    S3 Build Thread
    dan77's Avatar
    dan77
    Dec 2008
    Down south,
    195
    thanks for all the info guys, i`ll get the thermostat done aswell then, and as if the service and cambelt wasnt gonna cost me enough, it snapped a rear spring yesterday!
