JMB RetrofitsVolks Autos
    nickrex's Avatar
    Oct 2008
    45
    Alarm siren question
    Hi all.
    I have a problem with my alarm going off as soon as I lock the car and have put this down to the usual internal batteries playing up which I suspect is the culprit. Vagcom throws up every alarm fault code under the sun as you can see below so narrowing it down to any one sensor is useless.
    7 Faults Found:
    01371 - Alarm triggered by Door Contact Switch: Driver's Side
    35-00 - -
    01374 - 01374 - Alarm triggered by Terminal 15
    35-00 - -
    Possible Causes
    • Anti-Theft Alarm triggered by Ignition Switch (Terminal)
    • False Alarm
    01370 - Shareware Version. To Decode all DTCs
    35-00 - Please Register/Activate
    • Anti-Theft Alarm triggered by Signal from Ultrasonic Sensor Control Module (J347)
    • Ultrasonic Sensor Control Module (J347) faulty
    • Wiring/Connectors from/to Ultrasonic Sensor Control Module (J347) faulty
    • False Alarm
    Possible Solutions
    • Check/Clear Fault Codes
    • Check Ultrasonic Sensor Control Module (J347)
    • Check Wiring/Connectors from/to Ultrasonic Sensor Control Module (J347)
    01368 - Shareware Version. To Decode all DTCs
    00991 - Shareware Version. To Decode all DTCs
    Interior Lights 28-00 - Short to B+
    00955 - Shareware Version. To Decode all DTCs
    09-00 09-10 - Adaptation Limit Surpassed - Intermittent
    01134 -
    VAG-COM Version: Release 311.2-N
    Control Module Part Number: 8D0 862 257 E
    Component and/or Version: CV-Pump, Alarm, RC D17
    Software Coding: 15178
    Work Shop Code: WSC 06435
    1 Fault Found:
    01134 - Alarm Horn (H12)
    76-10 - Terminal 30 missing Intermittent
    Anyway, my question is until I get it sorted, can I just unplug the siren so I can at least lock the car or will this activate the siren due to the internal batteries? I dont want to try it in case it is constantly sounding without stripping down the boot to remove it. Otherwise any suggestions based on the vagcom results would be appreciated.
    Many thanks.
    Last edited by nickrex; 27th February 2009 at 15:34. Reason: half a word missing!!
    Feb 2008
    2,817
    yes you can unplug it. i have had the same issue with my s3. nightmare alarm going off at 2:30am. not good for neighbour relations! anyway the siren is in the boot near the cd disc changer well above it. can just simply be unplugged for the mean time
    nickrex's Avatar
    Oct 2008
    45
    Fantastic, thanks for the info. I've just had the boot apart so I can get to the siren so I'll unplug it now I know it'll be ok. Luckily the car is kept in the garage so I have been leaving it unlocked with no worries at home.
    Many thanks. Any other ideas on the cause regarding the vagcom results would be appreciated although It's likely to still be the siren I think.
    jcb
    Sep 2005
    uk
    4,077
    i replace dthe internal batteries and still got the problem, just pulled the repeater unit out completely, works fine now!
    nickrex's Avatar
    Oct 2008
    45
    All done. I even managed to take it out without removing the side panel, tight and grazed my knuckles a bit but not too bad a job. Car locks fine now and nice and quiet(obviously!!). Cheers.
