AH FabricationsSky Insurance
    S3 chj's Avatar
    Nov 2007
    South Wales
    296
    how do you bleed the breaks
    hi iv changed my abs pump today but i can't get the breaks to bleed how the hell do you do it?
    S3 mods and tuning in progress
    nick-barnes07's Avatar
    Jun 2007
    gloucester
    550
    i think there is a bleed valve somewhere in the engine bay as well as on the brakes, not 100% sure though
    grathies's Avatar
    More Points Than Portsmouth FC
    Dec 2004
    Portsmouth, Hampshire
    1,355
    Should be the usual bleed nipples
    Be careful to start with the ABS pump, if it was fitted "dry" then they can be a right arse, we used to have alot of problems with them, they seem to trip out for fun!
    s3ollie's Avatar
    Jan 2007
    749
    there is also two bleed nipples on the master cylinder these need doing first then work from the furthest away caliper back the the closest.
    as garth says you might also need to cycle the abs pump using vagcom
    8P S3
    S3 chj's Avatar
    Nov 2007
    South Wales
    296
    thanks guys i got a mate from vw coming up tomorrow with his computer to run the pump and code it, what a pain just to change a abs pump!
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    I used this guide to completely bleed the system on my A3
    http://forums.vwvortex.com/zerothread?id=3184085
    easy job
    ^^ In my opinion
