AH FabricationsSky Insurance
    sparx's Avatar
    Dec 2008
    East Anglia
    38
    Removing rear door panels A3 5 door (8L 2001)
    As the title suggests. I can find plenty of answers on here if you have a 3 door A3, but not a 5 door A3.
    Is it going to be the same as removing the rear door panels on a 3 door? I'm guessing it isn't.
    Thanks in advance,
    Sparx
    What am I, chopped Liver?
    807
    Yep Ive done mine same as the fronts-
    Remove the 2 mouldings from the front and rear upper corners of the panel they sort of slide upwards a flat head screwdriver will help - this will reveal 2 screws, remove these
    Remove the small torx screw from the doorpull/window switch, This will then release the window switch, pull it up from the front and you can remove it.
    Then remove the door card by lifting the panel and bringing it away from the door.
    Easypeasy when youve done it once
    sparx's Avatar
    Dec 2008
    East Anglia
    38
    Thanks very much for that I will give it a go at the weekend.
    sparx's Avatar
    Dec 2008
    East Anglia
    38
    benr, another question !
    Actually, forgot to say. Did you happen to get a look at the speakers in the rear doors? What size were they?
    807
    Nope i didnt really get a look, id be interested if you could find out the speakers size though. Also could you also have a look as to where the speaker is wired to, ie where do the wires go? a picture would be great.
    P.S i believe the speaker is attached to the door card and not the actual door.
