Wednesday,18,February,2009,20:23:38:41394
VCDS Version: Release 805.1
Data version: 20081017
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Address 01: Engine Labels: None
Part No: 8L0 906 018 N
Component: 1.8L R4/5VT 0002
Coding: 05710
Shop #: WSC 00736
3 Faults Found:
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
Part No: 8N0 907 379 E
Component: ESP 20 CAN V003
Coding: 18448
Shop #: WSC 06435
3 Faults Found:
00778 - Steering Angle Sensor (G85)
62-00 - No or Incorrect Adjustment
27-10 - Implausible Signal - Intermittent
37-10 - Faulty - Intermittent
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 D
Component: A3 KLIMAVOLLAUTOMAT_D75
Coding: 03141
Shop #: WSC 06313
5 Faults Found:
00787 - Temperature Sensor in Fresh Air intake duct (G89)
30-10 - Open or Short to Plus - Intermittent
00779 - Outside Air Temp Sensor (G17)
00797 - Sunlight Photo Sensor (G107)
30-00 - Open or Short to Plus
01297 - Sensor for Vent Temperature; Footwell (G192)
01206 - Signal for Duration of Ignition Off Time
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 G
Component: Airbag Front+Seite 2008
Coding: 01104
Shop #: WSC 06435
No fault code found.
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 980 BX
Component: AB-KOMBIINSTR. VDO D09
Coding: 00442
Shop #: WSC 00736
Component: AUZ7Z0X1315528
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0X1315528
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
1 Fault Found:
00526 - Brake Light Switch-F
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 P
Component: CV-Pump, Alarm, RC D13
Coding: 13166
Shop #: WSC 00736
11 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01365 - Lock/Unlock Switch; Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
01134 - Alarm Horn (H12)
76-00 - Terminal 30 missing
77-00 - Internal Supply Voltage
49-00 - No Communications
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00002
Shop #: WSC 06435
Coding: 05710
Shop #: WSC 00736
3 Faults Found:
P0411 - 35-00 - -
Coding: 18448
Shop #: WSC 06435
3 Faults Found:
Coding: 03141
Shop #: WSC 06313
5 Faults Found:
Coding: 01104
Shop #: WSC 06435
Coding: 00442
Shop #: WSC 00736
1 Fault Found:
Coding: 13166
Shop #: WSC 00736
11 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
00956 - Key 2
Coding: 00001
Shop #: WSC 00000
Coding: 00002
Shop #: WSC 06435
