Alarm Siren Fitment - HELP
audi18tdan
Ottawa, Canada
I need to fit this new siren unit and i only have the steps based on a TT.
So anyone got any ideas on where abouts in the rear-left boot panel i could find this as got the sub unscrewed but won't come out through access panel?
Many Thanks
ALL DONE.
Was directly below the sub
The new one is a slightly different unit and has larger bolt which requires a large holed mouting plate (available at £9) from Audi or drill it.
You dont even need to drill it you can make the hole bigger with a file .
Works a treat 1 problem is there is no point having it !:icon_thumright:
ALL DONE.
& if you used the search option within AS you would see posts by myself & others directing you to the siren location, exactly the requirements for replacing including a bigger hole & new larger nut.
11
984
9
661
