Volks AutosJMB Retrofits
Page 1 of 3 123 LastLast
Results 1 to 40 of 108
Like Tree2Likes
Thread: Top Speed of an Audi S3
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    This post is an edit of and edit of an edit so if you search this in 6 months time, only this first post will make sense, and maybe some of the later ones!
    I just wanted to clear up the S3 top speed thing.
    You can see the gear ratios in the picture below, they are for a standard S3 6 speed box.
    If you remap with the major remappers, then your rev limit is raised to 7200rpm. I've not personally seen an S3 with anything above a 7500rpm limit as firstly with the turbo they have stopped producing torque by then, and also the S3 engine would start self destructing at anything above this.
    I have however input the gearchange at 7200rpm to illustrate the maximum top speed attainable in 6th gear.
    As you can see 7200 is not a very suitable point to be changing for the gearbox.
    Due to the nature of the turbo, and looking at RR graphs, I would expect people to be changing gear at 6000rpm, and for the car to be dropping power thereafter.
    Pic:
    As you can see, the maximum top speed attainable in an S3 with the standard gearbox is 181mph. I have assumed the 3.27 final drive, though this figure 'may' be wrong. Several sources have reported this or 3.32.
    You cannot possibly go any faster than this, physics does not allow this to happen.
    However, if you're looking at your speedometer, they can be up to 10% incorrect thus it may appear as if you are travelling at 200mph.
    If you have a big turbo S3, your top speed will NOT increase unless your rev limit increases. You will however, reach that top speed a lot quicker.
    Lets say you have new rods, pistons, rod bolts, the works. Then you might get 8000rpm which will give you a top speed of 201mph.
    At the standard rev limit of 6500rpm you could feasibly attain 163mph.
    However, none of the above number are correct until you consider horsepower. Given the K04 turbo, you would reasonably be able to expect 150mph from the car. (assuming a realistic 260Bhp)
    There is quite a few people on this site quoting higher top speeds than physics actually allows, taking into account rev limit and engine power including one person even claiming 175mph!
    SHENANIGANS!
    We can work out the actual top speed of an S3 if we can get the information on frontal area, drag coeficient, rolling resistance and engine power.
    However, we can assume a general rule that production cars with known top speeds are running a correct horsepower figure to get there.
    To get over 170mph, almost every production car has close to or over 350Bhp, with the lowest horsepower figure I can think of to attain a genuine 170mph is a Porsche 911, a car with a far more aerodynamic profile, lower drag and a naturally aspirated engine.
    This difference regarding N/A and a turbo car is important, as turbo engines tend to produce power very slowly after their midrange punch, and it takes a long time for power to develop higher in the rev range, whereas a N/A car will produce power right up to the redline.
    As is discussed further down the page, power has to DRASTICALLY increase once you hit the aerodynamic wall to continue to go faster, and that aeordynamic stop is somewhere around 140mph onwards.
    If anyone has some more information, like proper datalogs, not anecdotal evidence, it would be cool to get them in this thread...
    EDITED TO REFLECT NEW INFORMATION ON FINAL DRIVE
    <Insert meaningless geeky specs here>
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Good info Dave.
    ...and something some of us already knew.
    175 MPH...yeah right!
    Anyway...who's spreadsheet is that?
    Can you send me a copy please?
    Looks handy.
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
    A3_Turbo's Avatar
    Swaying towards IHI....
    Jul 2006
    Virginia water, surrey
    1,441
    Dave,
    Fancy doing one of those for an A3 5 speed box K03S bla bla bla you know the spec...
    Cheers :D
    j
    A3 1.8TS
    K03S,Pro Alloy FMIC, Neuspeed TIP, Forge 007P,Jabba Stage 2, BMC CDA, Turbo Back Miltek,H&R Cup Kit,H&R Arb's,18" Cup 3's Wrapped in Parada Spec 2's, Facelifted, 10k Hids, Dewipered, Debadged,S3 Interior, S3 Rear bumper, S4 Front bumper, Brembo's, Momo Team, LCR Splitter.
    AS3TOM's Avatar
    Jan 2009
    Blackpool
    188
    if thats the case then why do audi state a top speed of 148-151 (facelift) for 8L model and 155 for the 8P?
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    That is most probably true, and I find your efforts of winding up S3 owners commendable.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Quote Originally Posted by AS3TOM View Post
    I'm not exactly sure the figures are MPH accurate...some tyres have a higher rolling radius than others, tyres 'grow' when hot and under centrifugal force etc...but the difference is going to be a handful of MPH either way.
    Not 25 MPH as some fools have suggested.
    Please note:
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Edited this as Audi cant even seem to publish the right final drive info in one place for the 8L.
    AS3TOM's Avatar
    Jan 2009
    Blackpool
    188
    good stuff, interesting post!!
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Quote Originally Posted by A3_Turbo View Post
    Dave,
    The spec of the car makes no difference apart from the rev limit, as the speed is worked out dependent on the relationship of the gears and the speed at which they can turn.
    However, the 02A/J 5 speed box, which I think is in your car produces the following results:
    27,096
    Very interesting, lets just say I may have seen an S3 according to the speedo doing 155-160 down the M11 a few years ago, but do you really think it can be as much as 14mph out on the speedo, thats a fair whack huh, certainly seemed that fast when I saw it, lol
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    18mph is the legally allowable 10% the speedo can be incorrect.
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    And to complete the set, the six speed 8P gearbox info. Taken from Audi's datasheet on the 3.2 TT
    Remember that the top speed figures are the speeds that can be attained using that gearing.
    To actually attain those speeds you need the power in the engine to get there. The 8P does NOT have enough power to hit 181mph.
    With a massive turbo it might, but you are getting into a whole other branch of physics working out the Horsepower needed to get 181mph.
    (About 340 upwards would do it eventually)
    27,096
    would of been nice to have a laser speed check on that S3 I claimed to have seen, just out of curiosity if the speedo is that much out, I wonder if thats worth a check on a long straight race road, I'm intrigued now.
    A3_Turbo's Avatar
    Jul 2006
    1,441
    Interestingly, showing a higher attainable top speed due to the different gearing ratios.
    So theoretically, on the bonneville salt flats, given no traction issues, your car would have a higher top speed than an S3.
    Wow, so S3 Top speed 141 mph my A3 175 Mph. That saying bet it would have to be a massively long straight to obtain that sort of speed!
    Jason
    A3 1.8TS
    AS3TOM's Avatar
    Jan 2009
    Blackpool
    188
    your a3 wouldn't reach 175 mph, not enough power in the engine
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    You'd need a lot more than your current BHP to get anywhere near 175mph.
    Olly P's Avatar
    My other cars a mk2 Golf GTi
    Dec 2008
    Oxford
    686
    Ha ha, SHENANIGANS!
    A3_Turbo's Avatar
    Jul 2006
    1,441
    How about HTC'S A3 then? He would be near the 175 mph mark surely?
    Jason
    A3 1.8TS
    Works 60% the time, Everytime.
    Jul 2008
    Up North
    1,577
    Jason
    And probably 400bhp lol
    2003 Audi S3 + Go faster bits
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    To work that out you'd need to know the Horsepower, Drag co-efficient, frontal area and rolling resistance at a minimum.
    But I doubt it.
    I'm fairly sure you need something close to 400Bhp to do it on a normal car.
    Porsches do it on 380Bhp but they are super aerodynamic in comparison to an Audi A3/S3.
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    This thread is quite interesting Dave and good to know things like this
    What do you reckon the top speed for jonnyc old beast running at 417bhp and BigAndy S3 Running on 437bhp i believe?
    Im sure another member madalex live local to me with a s3 running at 370bhp+ sure he claimed on his facebook 181mph in his s3. But might of been 181mph to do with his father car.
    Just to make sure im on the right track now a 8p s3 running over 340bhp+ should be able to hit 181mph? But would need to work out bhp, every thing out etc.
    I would love to actually see or be in a s3 which can reach those type of speeds but i can really picture a s3 at the moment doing that. Thanks
    Ashley
    Quote Originally Posted by Dave_Bayern View Post
    Dark Vader Half sibling - MyThread
    27,096
    Quote Originally Posted by benskin07 View Post
    & if you believe him then I'm seriously ashamed of you Ash, lol
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    It doesnt really matter an awful lot how much BHP they are running. The absolute maximum speed depends on the gearbox, not on how much BHP they have.
    Obviously they need to have the Bhp in the first place to turn those gears but there is a point where the engine can turn very fast, but the gears can't physically turn any faster.
    I've never seen a 1.8T engine with a rev limit more than 7500rpm, so the absolute fastest that car would EVER go, even if it has 1000Bhp would be 170Mph.
    I seriously doubt an 8P with less than 400Bhp would get to 181mph.
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    Lol well no i dont because if any one is going to be able to do it would be bigandy car or jonnyc old s3. There the only s3 i can think which would get close enough to do that, with all the mods and every thing. So dont be ashamed of me Nigel lol
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Ashley
    After doing a little bit of maths, closer to 400Bhp.
    340Bhp probably wouldnt be able to do it.
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    Ahh i understand you know Dave. Sorry for being rather slow....Thanks for that mate. So in less rev limits has gone up and gear upgraded im guessing. The only thing its really doing is making the car faster in the revs for example like 60seconds standard 8p i believe 5.6 seconds and i think jonnyc was doing 4 some thing seconds so with all the mods there will be no difference in the top end speed. In less gearbox upgraded or different ratio gears. Thanks for that input Dave. I dont know if they every did do any thing with the gearbox or different ratio gears installed.
    I've never seen a 1.8T engine with a rev limit more than 8000rpm, so the absolute fastest that car would EVER go, even if it has 1000Bhp would be 156Mph.
    So unless the car has a new gearbox, or different ratio gears installed, it literally will NEVER go faster than 141mph with the standard 7200rpm rev limit or 156mph with an 8000rpm rev limit.
  28. #27
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    Thanks for that Dave. I will stop asking to you work out every thing now ha.
  29. #28
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    reminds me of a old argument I used to have with the mk2 golf boys, my crx would do over 60 in 2nd but golfs wouldn`t. One lad insisted his would until he took me in the car and hit the rev limiter at 55 ish lol.
    red to red black to black blue to bits
  30. #29
    AS3TOM's Avatar
    Jan 2009
    Blackpool
    188
    there is a saph cossie that goes 200mph + thats around 800bhp, just goes to show its to do with the gearing as well as the power its churning out
  31. #30
    Jun 2008
    115
    My GPS at Bruntingthorpe mind you, showed 148mph? so is my gps wrong?
  32. #31
    Jul 2006
    1,562
    Excellent post, and a great reality check for the dreamers lol
    It's the same over on Vectra forums etc too,.............there's always a few deluded fools claiming 170mph or more.
  33. #32
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Doesnt the 02m gearbox in the S3 run two final drive ratio's, one for 1st to 4th and one for 5th, 6th and reverse? Cant find the info at the moment but i was under the impression that 4.2 was the final drive for 1st to 4th and therefore the the S3's actual theoretical top speed will be higher than youve calculated above.
    2007 A3 TDI 170 S Line
    Sold - 2002 S3
  34. #33
    Sep 2008
    Scotland
    86
    This might well be a daft question... but why are 4th and 5th gear following exactly the same line on your first s3 graph?
  35. #34
    V.I.P_UAE's Avatar
    Jan 2009
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,361
    excellent thread Dave! Reading the first post I was all set to dispute it, having seen a fraction over 150 on the GPS in my fwd 1.8T A3 (not on public roads). Then I read your post regarding the A3, and I'm happy again.
    I know for sure I'm proud to have an o2J, I personally think the 1.8T doesn't need 6 gears....
  37. #36
    Jan 2007
    107
    I have done 165MPH in my S3( AMK)(17" wheels) with APR remap, and that was going of my road angel. I was only at them speeds for about 30secs though and it was down hill.
  38. #37
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,361
    Quote Originally Posted by S3Matt View Post
    If you look at the figures Dave has inputed, 5th gear should be 1:1, but Dave has accidentaly written 1.1, making it marginally higher than the 1.09 of 4rd gear.
    Just a little typo
  39. #38
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Prawn,
    The specs say 5th gear 1.1:1 and not 1:1.
    And S3 steve is indeed correct, there are two final drive ratios! (Its obvious on the Audi website for the 8P but not so for the 8L).
    However, it does change things, I have edited the initial post to reflect this.
  40. #39
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    I did the claculations wrong on that picture again.
    With a 3.32 final drive it would mean 178mph!
    However, I've read 4.2, 3.32, 3.65 and number inbetween for the S3 gearbox, can someone find me a definite gearbox code or final drive ratio for 5th and 6th on an 8L Audi S3 then I'll update the first post with a correct picture/figures.
  41. #40
    AS3TOM's Avatar
    Jan 2009
    Blackpool
    188
    what would it be with 17inch wheels?
