AH FabricationsSky Insurance
    Feb 2009
    A3 Double din help
    Hi,
    I have a 2002 A3 1.9tdi, and have the bose sympthy system from factory. the head unit is double din, and i want to change this to a single din unit for my aftermarket head unit. where can i find the fascia that changes the double din to the single din with the compartment underneath?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,038
    Sadly there is no such beast for the 8L A3/S3, I know... I was looking to do the same thing.
    Your choices are, get an A4 double din facia and trim it or source all the original bits to change from double din to single din.
    I did the latter and sourced a single din cage, aircon unit and lower compartment.
    Feb 2009
    thanks, i can probly get one from the stealers but they cost 's was wondering if there was a cheaper option
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,038
    Scrap yard or someone who wants to swap a single din for your double din setup for the cheap option.
    The aircon unit alone is about 400 from a stealer.
    This is the facia I first played with before going for a single di swap:
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=400017913439
    If you go single din, you will need one of these:
    http://www.dynamicsounds.co.uk/produ...oducts_id=8782
    I have one on order as these are rubber/soft touch finish like Audi head units. The one I have in at the moment is a bit shiny
    <tuffty/>
    a3-ams's Avatar
    Jan 2009
    London
    58
    Hey mate,
    Did you have any luck? What option did you go for????
