EM TuningVolks Autos
Page 1 of 2 12 LastLast
Results 1 to 40 of 43
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,150
    VAGCOM Torque/BHP graph
    Deece posted up the guide to do this from Ross-Tech's website last week so I thought I'd gove it a go. This is what I got:
    For those of you that have had dyno graphs done and or have done this graph in VAGCOM can you tell me if it looks ok?
    I hit max power of 221HP at 5700rpm and max torque of 227lbft at 4500rpm
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Works 60% the time, Everytime.
    Jul 2008
    Up North
    1,577
    Not bad. Fairly smooth power curve apart from the slight flat spot at 4500rpm.
    2003 Audi S3 + Go faster bits
    jimbobery's Avatar
    S3
    May 2008
    257
    Looks ok to me, not that I've had a dyno graph done, or that I know what I'm taking about :-)
    But, I do know that your torque and power are supposed to cross at exactly 5252 rpm, which yours does. Its to do with how bhp is calculated from torque and rpm (5252 is in the formula)
    I did a graph at the weekend actually so I'll post it tonight - then you'll see why you should have a remap!
    Westy's Avatar
    Dec 2008
    17,150
    Yeah get your graph up matey.
    I was only doing this to make sure I didn't have a problem because I had fluttering noises when boosting but its only occaisionally. I think this graph and my boost graph prove I'm running ok. A remap is on the cards soon. Just need to decide where to get it done.
    S3 Build Thread
    jimbobery's Avatar
    S3
    May 2008
    257
    Here's my latest one. Its a bit smoother than yours, but I think it would depend on road conditions etc so probably nothing to worry about.
    I got a maximum of 265ftlb and 265bhp, which is what its supposed to be with the remap, and I've only read on here etc that the torque calculation from the bosch sensors is accurate.
    I think the thing to remeber with this is that vagcom only logs once every 1/4 of a second or so, therefore you might actually miss your maximum reading, I definiately found this to be the case with checking the maximum MAF reading.
    Jun 2007
    614
    Where is the guide to get produce these graphs? I've got VAG-COM, so I wouldn't mind trying it out for myself.
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,089
    yeah i wouldn't mind a look at the guide and give it a go..
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    jimbobery's Avatar
    S3
    May 2008
    257
    Its not so much a guide, more a collection of all the vagcom logging info I could find pasted into a word doc.
    I've pm'd you both
    Feb 2009
    69
    Couldn't shoot it this way could you mate.
    jimbobery's Avatar
    S3
    May 2008
    257
    No probs - PM me your email and I'll send it over
    Feb 2009
    69
    Thanks for that mate
    Westy's Avatar
    Dec 2008
    17,150
    Post up your graphs lads when you've done it.
    S3 Build Thread
    PM Sent
    Westy's Avatar
    Dec 2008
    17,150
    Whay are we all PMing this around when we can share the wealth.
    http://www.ross-tech.com/vag-com/cars/index.html
    download the "Block 120 spreadsheet" half way down the page.
    S3 Build Thread
    jimbobery's Avatar
    S3
    May 2008
    257
    Yep, screw PMing, I've uploaded the word document here:
    S3 VAGCOM Checks.doc
    thorsy22's Avatar
    Jul 2008
    West Sussex
    307
    Thanks for the pm earlier deece.
    2001 Audi S3 - AMK 210bhp
    Tarox F2000 discs front - Tarox 401 Rallye+ pads
    Tarox F2000 discs rear - Tarox 112 Strada pads
    Goodridge brake lines
    TT pedals
    N249 bypass
    Finally back on the road, have a HUGE list of mods and things to do now!
    Andy_S3's Avatar
    May 2007
    Teesside
    719
    Quote Originally Posted by Westle View Post
    Just had a play with mine and got virtually identical results to these, so it cant be that bad!
    Westy's Avatar
    Dec 2008
    17,150
    Good i'm glad i'm not the only one with un smooth power curves
    S3 Build Thread
    freegeek's Avatar
    Jun 2008
    Dunfermline
    159
    Would be interesting to compare one run with the this method and the bhp = MAF/.8 to compare the two sets of results.
    Mine looks like this with the maf method, I used this as I had heard that the torqu calculationfor the ECU could be innacurate when mapped, but that could be incorrect.
    If I get time i'll mod the code to plot the curves with both sets of data.
    jimbobery's Avatar
    S3
    May 2008
    257
    I did a MAF run straight run after the torque one above (same road, same conditions etc) and got this:
    Engine RPM: 6600
    Air Mass: 220.97
    Thats the highest air mass flow I've ever got, although all other runs I've done were in 18degC or above last year (not sure if that makes a difference).
    So thats 220/0.8 = 275bhp. I'm very sure my car doesn't have 275bhp!!! I think the MAF/.8 calulation is only a general guide.
    I've only read that the ECU torque calcultations are actually accurate, even when mapped (except on Passats for some reason ?!?).
    Measuring lbft and bhp is all a bit random anyway, what with the stories you hear of dynos giving higher than true readings and then people quoting figures as fact. I only log this stuff to check I haven't actually lost any power due to faulty MAF, DV etc.
    I am impressed with the 'liquid' though - looks to be a well thought out bit of kit!
    Westy's Avatar
    Dec 2008
    17,150
    I alos was only interested in this to rule out a boost leak as I was hearing some strange fluttering noises when boosting.
    It would be very interesting to see how different the readings are between the 2 methods.
    Post up the graph if anyone gets time to do it.
    S3 Build Thread
    Feb 2009
    17
    Hi. New to the forum. Hi everyone. Just put my figures into the Spreadsheet. A little dissapointed with the results. Straight road in 3rd pulling from about 1300RPM up until Redline.
    HP = 230
    Torque = 260
    It has had a revo Stage 2 supposibly 260HP/280lbft.
    Have I done this correctly. Car seems to be pulling smoothly, throwing no fault codes.
    Jun 2008
    194
    vagcom dyno's aren't accurate with performance software as the calculation's used are based on stock software so they are a compleate waste of time for power figures!
    bst off getting the car dyno'd properly!
    Feb 2009
    17
    Thats what I was hoping. Just wondered why some people were getting expected figured even running tuned software?
    Extras are:
    Miltek Race Re-Circ Valve
    Powerflow Full Exhaust/Decat
    GruppeM Intake
    Would you advise any changes?
    Jul 2008
    Up North
    1,577
    Quote Originally Posted by s3wil View Post
    Extras are:
    GruppeM Intake
    Allways been wary of custom exhausts. Not saying its certain but Ive known people to lose power with the custom powerflow exhausts. Depends on garage that did it though.
    jimbobery's Avatar
    S3
    May 2008
    257
    Quote Originally Posted by revo carl View Post
    This is a bit of a sweeping statement! How is it that so many people get expected results using this method?
    This quote from the guy who made the vagcom software is more likely to be accurate:
    That depends on the approach the chip-tuner takes. Sometimes they have to "fudge" the torque calculation in order to bypass other limitations in the firmware. (from here)
    So some remapped cars don't produce accurate results using vagcom and some do, but not Revo as they fudge the torque calculation (not putting down Revo tho).
  28. #27
    Feb 2009
    17
    Just logged the MAF under WOT and it gave 205g/s. A website indicated to multiply by 1.31 as a rough guide = 268BHP.
    Interesting topic. Keen to get it done on the rollers now as it would really clear up some theories. Although as someone pointed out the VAG Dyno method is a great way of testing how modifications affect performance.
    Thanks for your input.
  29. #28
    freegeek's Avatar
    Jun 2008
    Dunfermline
    159
    Guys, I am trying to improve the accuracy of the liquidS3 BHP and Torque figures. Today I calculate bhp and torque using the maf data but I am not sure if this is the best/most accurate way.
    So I use;
    bhp = maf/0.8
    torque = bhp * 5252 / rpm
    however vag-com also provides a torque figure directly thus bhp can be calculated with this;
    bhp = torque * rpm / 5252
    To verify which is best I need some vag com logs from both stock and mapped cars, the logs need to be done in 3rd gear, from 1k rpm to the red line with full throttle logging only block 2 and block 122.
    I have plotted the data from my car doing two identical runs below. The plots on the left are what you would get from the liquidTT the ones on the right are using the alternative calculation metod.
    I hope you can send me your logs.
    Cheers Jim
  30. #29
    jimbobery's Avatar
    S3
    May 2008
    257
    The problem with the MAF calculation is that is misrepresentative when you get up the top of the rev range.
    You can see BHP continue to rise all the way to the redline, but this isn't likely as its common for power to drop off at the top of the rev range; over 5500rpm you can feel the power reduce on the S3 and I've read many comments that the best time to change gear is at 5500rpm as this is where peak power occurs.
    Anyways, bearing this in mind I think your graphs show that using the VAG Torque Method is more realistic.
    Prehaps you could display both methods making it clear about the differences between the two, MAF readings are still useful to know?
    Out of interest what language are you using to capture and display the info from the ODBII port? I just wonder if you can open out to Developers like Facebook has?
  31. #30
    jimbobery's Avatar
    S3
    May 2008
    257
    Quote Originally Posted by freegeek View Post
    I have some logs I can send you, PM me your email address.
  32. #31
    Jul 2008
    Up North
    1,577
    Quote Originally Posted by deece View Post
    To be fair that "feeling" of reduced power is the drop off of torque. Thats what pushes the car and thats why its best to change well before the limit.
  33. #32
    freegeek's Avatar
    Jun 2008
    Dunfermline
    159
    Can you remember where you read this, getting good data on this is very difficult, I had read that the ECU torque calculations were inaccurate for mapped cars, but again that was just forum speculation.
  34. #33
    Feb 2009
    17
    Well after feeling the car wasnt quite going as it should and getting less than expected vag com logs, yesterday I followed a guide found to test for vacuum leaks.
    Blue peter style I connected a sweetcorn tin up the the intake with a pressure line adapter on, clamped off PCV pipe and raised to around 10psi. Instantly I heard alot of leaking air. Firstly a pipe near the dipstick had split and secondly once I fixed that I could hear the pink 90 degree hose pipe coming from the turbo at the rear of the engine hissing also. Once I removed this, easier said than done! I could see it was badly cracked inside and out.
    The stealers wanted 89 for this so ended up getting a silicone pipe off the internet for 17!
    With slight modification fitted. I then retested and couldnt find any more leakjs but is it right for the air to be escaping from oil cap (removed)
    Now the car pulls alot more smoothly and although the placebo affect maybe playing a part the car feels a little bit more powerfull.
    Job done. I highly recommend the pressure test. Will post Vag Com LOGS soon. Great forum, shame full audi servicing didnt pick this up!
  35. #34
    Westy's Avatar
    Dec 2008
    17,150
    Nice work Wil get the logs up. I would like to do this too as I have strange noises when boosting but the car feels ok most of time.
    S3 Build Thread
  36. #35
    Jul 2008
    Up North
    1,577
    Well there you go. Proof the the Turbo pipe at the back of the engine can fail...
  37. #36
    Westy's Avatar
    Dec 2008
    17,150
    Can someone stick up a pic of where this pipe is because i've now heard of several boost issues that were caused by that pipe.
    S3 Build Thread
  38. #37
    ianysm's Avatar
    Oct 2008
    UK
    1,001
    Have you got a link to this vacuum leak guide?
    All interesting stuff.
    Current: RenaultSport Clio 172
    Previous: 2001 ('51) S3 Quattro
    Previous: 2001 E46 M3 Coupe
    Previous: 2001 Civic Type R
  39. #38
    Westy's Avatar
    Dec 2008
    17,150
    I've just done a quick search on Ross-tech's website and cant find anything so a link to the guide would be greatly appreciated S3Wil.
    S3 Build Thread
  40. #39
    Jul 2008
    Up North
    1,577
    Its at the top back of the engine. Just under the strut brace. 90 degree bend and red. Comes straight off the turbo.
  41. #40
    Westy's Avatar
    Dec 2008
    17,150
    Many thanks Minty I'll check that tomorrow.
    S3 Build Thread
