EM TuningMonster Motorsport
Results 1 to 10 of 10
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    Indicator irregular flash?
    Hi all, just quickie. My indicators started flashing irregularly both sides. The hazards flash perfectly.
    Maybe its the relay but where is it?
    Cheers ian
    AUTOMAP
    Mobile ECU Remapping Services
    automap.remapping@gmail.com
    www.eliteremaps.com
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    Relays are all under the steering wheel area under the bottom part of dash along with the fuze box.
    Black S3
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    I think the relay is incorporated into the hazard switch itself. Are all your bulbs intact?
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    Hi yeah the bulbs are intact. I also put the question into google and indeed it would appear that the Hazard unit is also the indicator flash unit too. I wonder if i can swap relays for now so the indicators work but the hazards are irregular?
    If you listen by the hazard switch with indicators on you can hear the relay engaging
    Ian
    AUTOMAP
    www.eliteremaps.com
    jimbobery's Avatar
    S3
    May 2008
    257
    The two relays are in the same unit, would probably be more effort than its worth to swap them. Its about 30 for a new relay unit (its actually the hazard button itself)
    There is loads of stuff on here on how to change it. Its a bit fiddly but not too bad. If you've got a piano black interior you need to be careful not to chip it when removing the panel in front of the hazard switch.
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    Cheers, yep i've got the piano black. I'll order one from Audi then and get around to swapping it. I assume the problem will only get worse. Right now its just irregular but i bet it'll stop altogether soon!
    AUTOMAP
    www.eliteremaps.com
    jimbobery's Avatar
    S3
    May 2008
    257
    Mine was only slightly irregular for a few months and then got worse very quickly until they stopped altogether, just before MOT time! It was surprising how worrying it was driving around without being able to indicate!
    nicklght's Avatar
    Imthegod
    Oct 2006
    South wales and Portsmouth
    217
    Hey this happened to me a few weeks ago, and it is the hazard relay.
    Do the indicators come on some times but not all the time?
    If so try GSF i think i got a realy for 20
    Nick Light
    jimbobery's Avatar
    S3
    May 2008
    257
    I just randomly the box for my new hazard relay: part number is 8L0 941 509L
    Apr 2007
    297
    Hi I did a write up on this just before Christmas - see below link and scroll down to 'The Fix':
    Piano Black trim removal (Hazard LIght Switch)
    Good luck :-)
