AH FabricationsChris Nott
Results 1 to 17 of 17
    jays3's Avatar
    Jul 2008
    75
    juddering after remap
    i know its prob the a coilpack, but wanted a second opinion, i had my car remapped 2day and im over the moon, earlier today the engine management light started flashing, also the car has no power and is lumpy on tickover, also how much is all 4 coilpacks as i may aswel replace them all, thanks for any help
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    Coils packs are 30 to 40 each, sounds like one has failed.
    Black S3
    Feb 2008
    529
    eurocar parts sell genuine audi/vw ones for 26 each
    Audi A4 Avant 1.9TDI Quattro Sport 2004
    jays3's Avatar
    Jul 2008
    75
    cheers guys, i just went out in the car and all was fine, no doubt it will come back tho, could a coilpack be tempremental or maybee the car is still adjusting, what do you think
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    Get the codes read via vagcom or a codereader asap and see what its saying to ya.
    Black S3
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,640
    Probably the coilpacks, remaps do normally bring up any issues, they cost about 30 each, make sure you do go for the genuine ones from Audi, they are a couple of quid more expensive thank euros/gsf ones, but they last alot better compared to the others.
    h100vw's Avatar
    Aug 2006
    Down South, next stop Antarctica
    215
    If it clears by cycling the ignition and then doesn't come straight back, I wonder if there is another problem.
    I had a coil pack go on a Leon Cupra but there was an intermittent boost problem too. I found a slack hose clip that was allowing boost to leak out when the engine was cold. If you booted it, then you got a soft limp. If you hung on until the car warmed up before booting it, there were no problems.
    The code it threw was p17705 I think, it pointed to the DV but that was forge one so I ignored it and looked elsewhere for leaks.
    Gavin
    jays3's Avatar
    Jul 2008
    75
    i will look under the bonnet in a bit, to look for any lose hoses, i am going to have to uprate the dv also as its still the standard 1. Is the car ok to drive
    h100vw's Avatar
    Aug 2006
    215
    If it doesn't sound like a Subaru you should be ok. Running it with a dead coilpack could harm your cat with the unburnt fuel.
    Gavin
    jays3's Avatar
    Jul 2008
    75
    i have replaced all 4 coilpacks but the issue wasnt solved, i know that is its cylinder 2 thats causing the problem so i tried another coilpack incase i bought a dud, still no luck im guessing now that the sparkplugs must be causing the problem, also i disconnected the battery to reset the ecu that made the EM light go out. any thoughts, cheers
    Nilz's Avatar
    Apr 2006
    9,640
    Have you had it on VAGCOM yet???
    If not get it on ASAP, as you are only going to end up spending/wasting money, second guessing what it could be.....
    jays3's Avatar
    Jul 2008
    75
    not yet mate, dont get a chance by the time i finish work, i have changed all the sparkplugs now still no luck, none of the new parts are faulty i know this because i have swapped them all around and its the same cylinder causing the problem, any ideas
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    You need it on vag-com ASAP!
    Black S3
    mattyboy199's Avatar
    Nov 2005
    UK
    1,677
    mine did this when i got it remapped ! coil packs it was
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    ianysm's Avatar
    Oct 2008
    UK
    1,001
    DV?
    Current: RenaultSport Clio 172
    Previous: 2001 ('51) S3 Quattro
    Previous: 2001 E46 M3 Coupe
    Previous: 2001 Civic Type R
    jays3's Avatar
    Jul 2008
    75
    had the car on vagcom today all was well no faults at all, however the guy i took the car to thinks that the plug that plugs into the coilpack is faulty, i rang audi and they sell individual coil heads so u dont have to replace the whole loom, only 30 so it will hopefully be sorted tomorrow, fingers crossed.
    Nilz's Avatar
    Apr 2006
    9,640
    Good luck Jay, hope you get it sorted....
