AH FabricationsEM Tuning
Results 1 to 10 of 10
    Nov 2008
    95
    Traction Control Wont Turn On When Driving?
    Hey all,
    I went to view an s3 today, decided not to buy it in end as all seemed a bit dodgy!
    but the traction control wasnt working properly
    it would turn on when the ignition was on, and stay on when started the car, but as soon as u start driving, it would turn straight off, and then the button for it wouldnt do anything, and u couldnt turn it back on?
    is this a common fault? and is it easy fixed?
    just so i know when i go and look at other s3s!
    Cheers Dan
    S3 NIK's Avatar
    Mar 2007
    190
    The esp light comes on with ignition then should go out as with the air bag light for example. The only time its lit is when you turn it off as a reminder its been manually turned off and when its actually working ie when you are losing traction, when this happens it flashes on and off quickly.
    Nik.
    Quote Originally Posted by VTI_EG_DAN View Post
    Hey all,
    Cheers Dan
    Nov 2008
    95
    yeh this light was on the whole time when driving, and when car was started the button wouldnt do anything, and warning light would just stay on
    S3 NIK's Avatar
    Mar 2007
    190
    In which case there's a fault somewhere and it would need a diagnostic check to pin point the fault.
    Nik.
    807
    Yep there will be a problem with it. as mentioned above It whould be off after you have started the car unless you turn it off by pressing the button.
    it could be a common problem as some of the sensors are known to fail, but needs a diagnostic scan to find which one. I wouldnt buy it until its sorted though
    Yaz
    Yaz's Avatar
    Oct 2008
    Essex
    225
    More than likely the longitude sensor or something like that has failed and needs replacing. This is a common problem with the TT also.
    When this happens, its ok to drive the car but just means the ESP wont work!
    1994 Audi 100 Avant 2.5TDI
    1987 VW Scirocco Scala
    mad max's Avatar
    sixth gear
    Jul 2006
    beyond the thunder dome
    335
    has the battery been played with because there is an plug in on the back of it and if its not making a good connection would cause this type of fault.easy to check and could save you money if it is this
    S3 TUNED AT MRC
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    Mine used to come on due to the problem I had with my MAF. It did take a while but after a bit of spirited driving it would come on and sta on until I turned the ignition off.
    VAGCOM would help you... it may be a fault that a cheap fix or a way of getting a good price on an otherwise decent car.
    The seller must have known there was a prob (even if they don't know what it is)
    Good luck finding a car, its a buyers market and the right one will come along
    <tuffty/>
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Can also come on with a bad ABS sensor.
    807
    Quote Originally Posted by HTC View Post
    Yep but the abs light would also be on.
