    Nov 2007
    30
    Indicator lights does not flash when car is alarm!!
    My A3 1.8T has an alarm malfunction. When I lock with the key fob, the indicator light does not flash and the red door lights do not blink. So there is no indication that the door has been locked. On the other hand when I open the door that's the only time the indicator light flashes.
    The siren still works as normal! the problem only occurs when arming the car.
    Please help!!
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    try switching your sensors on, the door pillar has a sensor button..... it sounds like its arming but not fully...recall my 1.8T doing it when i hadnt closed the doors/boot properly
    it could be a sensor at fault if the above doesnt work
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,613
    I reckon it will fix itself if you open thee boot and slam it shut.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,284
    I have the same issue. I tried opening 1 door at a time and checking to make sure that the DIS shows each door/boot as being open when open and closed when closed. When my passenger door is open on its own my DIS shows that both my passenger and driver doors are open together. I'm going to have the door lock apart and check the sensor at some point.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,389
    a friend of mine had this same problem on his 1.6 A3, it turned out to be a fuse that controlled the interior lights and alarm. Once I replaced that, everything worked perfectly again.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    If the lights do not flash it means the alarm has not fully armed, i.e. a door is still open slightly.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
