    campbell's Avatar
    Apr 2006
    Lancashire
    712
    Question problem with steering on full lock?
    Hiya All,
    When i turn my steering on full lock (both ways) the tyres seam to slip/slide at slow speeds and produces a wierd noise. I have checked my wishbone rear bushes and they seam fine, checked the springs and they are not broken. Nothing obvious.
    It has only started doing it in these cold conditions, is this normal?
    Lee
    2002 225 S3, metallic black, REVO, 18" RSTT alloys, goodyear Eagle F1s, silver leather heated seats, tinted windows, H&R spacers, black diamond grooved discs & Ferrodo DS2500 pads, BOSE system, xenons, forge DV, samco TIP & upper boost hoses.
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,062
    I know it sounds silly, but have you checked your PAS fluid???
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    Perhaps the tyres are just sliding on the icey surface!
    AUTOMAP
    Mobile ECU Remapping Services
    automap.remapping@gmail.com
    www.eliteremaps.com
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    Will have to check the power steering fluid, would it give these symptons if low?
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    Is it a wirring noise?
    If the fluid is low it can cause this.
    AUTOMAP
    www.eliteremaps.com
