Monster MotorsportChris Nott
Results 1 to 9 of 9
    ruairi83's Avatar
    Dec 2007
    684
    Rear Tyre rubbing help
    My A3 is lower on spax springs and standard shocks.
    Took the back tyre off last week and the inside wall was well rubbed away...
    Could this be one of the shocks have gone? It pasted MOT no problem with no issues on shocks etc...
    Im running 18" rs6's with 225/40/r18 Khumo tyres...
    Any help appreciate.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Is it a quattro?
    S3 Paul's Avatar
    Oct 2006
    2,759
    If its quattro... maybe something to do with the rear track control arms. The rear camber is thrown out when the car is lowered so scrubs the inside edges of the tyres... how long have the tyres been on?
    If it is as ive said and indeed a quattro then i would say... if its just one side maybe a bush on the track control arm has split/ perrished or if its the same on both sides maybe the car is too low for standard control arms to hold the chamber angle. I fitted KW adjustable rear arms and its sorted everything as they can be set to stock setting or a little camber to aid cornering,
    Noggy Blue 2001 S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    ruairi83's Avatar
    Dec 2007
    684
    its isnt a quattro. 1.9TDI
    S3 Paul's Avatar
    Oct 2006
    2,759
    Are. right,
    How long have the tyres been on ? Is it just on one side? how long have you owned the car?
    Noggy Blue 2001 S3
    ruairi83's Avatar
    Dec 2007
    684
    The new tyres are on a week but the old tyres where on a year. only on left rear.
    Just want to know weather to get shocks for back or bushes ???
    Own the car 1.5years.
    It was lowered on spax springs and standard shocks when i got it...
    S3 Paul's Avatar
    Oct 2006
    2,759
    Ah,
    well it doesnt look "too low" i would check with the lads on here that have non 4wd A3s . As the rear set up maybe comletely diffrent to what i see when i jack mine up. If it was a shocker i would expect it to be wet if its leaked or ride realy bad if its given up.
    I would look at the bushes on the rear... role bar links/mounts...
    Noggy Blue 2001 S3
    ruairi83's Avatar
    Dec 2007
    684
    Quote Originally Posted by S3 Paul View Post
    Ah,
    Cheers mate going to check out about bushes tomorrow.
    Thank for help!
