JMB RetrofitsBadger5
Results 1 to 25 of 25
Thread: s3 heated seats
    Haglos's Avatar
    jabba mapped
    Mar 2008
    242
    s3 heated seats
    my s3 has heated seats but they dont work ive had a little look and it looks like the loom is not there as the plugs under both seats are just hanging which i guess is for the heated seats and the controls are in the dash is it just the loom i need as it may have been cut. When i brought the s3 it was stolen recovered but not recorded and the seats came from a 2002 s3 is this a big job and whats involved any help would be appreciated thanks
    27,126
    You need to remove the seat & check whats left underneath from the previous seats then go from there, if the looms were cut then you need to get a new plug/s & maybe repair wires for those plugs & join them accordingly to plug into your seats, a good wiring schematic definitely needed from elsawin for your car, where abouts in UK are you?
    As I said there should be some looms under seat loose from the car itself to plug into your seats
    beeitch's Avatar
    Mar 2006
    Madrid, SPAiN
    64
    Don't worry mate, heated seats retrofit are possible, the only thing you must know it's if your car come with heated seats, so you have to see below and look for a GREEN PLUG. If you got one, those are heated seats, then you have to wire to start to use it.
    Retrofit wires are sold by Kufatec in Ebay.
    2002 A3 1.9 TDi QUATTRO S-LINE AVUS SILVER with full OEM Bodykit
    Haglos's Avatar
    jabba mapped
    Mar 2008
    242
    thanks for the reply its a 2000 w reg s3 and it does have the green plugs under both seats i will remove it and have a good look and im from essex near lake side
    Haglos's Avatar
    jabba mapped
    Mar 2008
    242
    its also got the controls in the dash for this i will have a look at elsawin
    27,126
    Then as I've already suggested, the loose looms could of been pushed under the carpet into the floor as they come from underneath anyway, so with luck they'll be sitting there awaiting plug in, if the dash has dials then it must have looms there, no one fits the climate with dials without heated seats, they're either hidden or been cut so do as above fella, plugs, repair wires & join etc with elsa's help, thus sorted, make sure use correct gauge wires given current load is about 10-15amps, dont need a fire, melted wires huh, lol
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    Quote Originally Posted by Haglos View Post
    By 'plugs' do you mean the green plastic plugs on the end of cables going under the carpet, or a green plastic bolted to the bottom of the seat? If you have both, then just plug them in.
    If the seats don't have them on the bottom frame, then I reckon the seats have been replaced at some point, but with unheated ones, so you would need some replacement heated seats.
    Cheers,
    Alistair
    "Why don't you listen to something really classical, like Mozart, Mendelssohn or Motorhead?"
    Arnold Rimmer, 1988
    Commuting & Weekend Fun:
    Yamaha YZF-1000R Thunder Ace in Blue/Black
    Practical Alternative (Still fun though!!):
    S3 2002/51 AMK Silver, Symphony II + Bose + xCarLink + AndyMac Stealth Sub, Metallic Mirrors, Heated Black Leather, Cruise control.
    Haglos's Avatar
    jabba mapped
    Mar 2008
    242
    yeah just had a look under seat and there is a green block plug on its own on both seats and i lifted 1 side of the carpet up on passengers side but cant see any wires ill have to dig further and on both sides
    27,126
    You need to remove the seats to check properly, takes 5 minutes max, undo 2 bolts slide to back with the seat leaned forward & lift out by lifting rear & swinging the front downward & towards the rear so the headrest is pointing towards the windscreen then should lift straight out, this will allow full view of the underseats then & check car fully for any wiring, I cant see why it would have climate with heated dials but no loom underneath
    Watch the runners on bottom of seats when lifting out dont hit any trims as easily scratches, many a time took mine out when had the S3 over 7 years, mainly cause audi couldnt fix something, can you believe I borrowed there workshop tools to fix my own car, useless, totally
    Haglos's Avatar
    jabba mapped
    Mar 2008
    242
    lol thats audi for ya it has climate but the dials are seperate from the digital climate mine controls are on the top next to the traction control i was thinking if i get the controls out i might be able to see if there is any wires attached to it then i can follow it
    27,126
    Ah you have pre-facelift as mine was, yeah they do actually just pull out, but be careful not to damage the piano black trim as thats tad rich to replace, if it has wires plugged into them then its gotta have loom somewhere & tbh, if it has them anyway at top then it must have heated seats, cause it requires trim with the holes for the dials, etc etc
    Haglos's Avatar
    jabba mapped
    Mar 2008
    242
    i just took the centre console out and the loom is there but it has defo been cut some where it looks like it is a dash out and that black trim i put a little mark on it as well this will be quiet a job is it easy to take the dash out
    FazS3's Avatar
    Apr 2008
    857
    isit possible to retrofit heated seats?
    MTM THE ULTIMATE STAGE!
    Haglos's Avatar
    jabba mapped
    Mar 2008
    242
    like run another seperate loom instead of hunting the exsisting 1 would be easier i have read before of people retrofitting heated seats
    FazS3's Avatar
    Apr 2008
    857
    i would love to retrofit mine anyone with any more info on this?
    27,126
    I did say watch the trim, lol, never mind
    But you're saying the heater dials are plugged into looms ok in cnsole?
    If so then I reckon its as I stated, they're either hidden under seats in carpet or they've been cut of under seats, both of which are fairly simple to resolve, just take the seat out as I suggested mate then you'll know, the time to mess with the centre console you would of had seat easily out/in with your answer, lazy arse, lol
    27,126
    Quote Originally Posted by FazS3 View Post
    If you are confident about taking seats apart then yeah might be able to get the heating elements from etka, but you'll need elsawin to do wiring for sure.
    thorsy22's Avatar
    Jul 2008
    West Sussex
    307
    I would love to retrofit heated seats too.
    2001 Audi S3 - AMK 210bhp
    Tarox F2000 discs front - Tarox 401 Rallye+ pads
    Tarox F2000 discs rear - Tarox 112 Strada pads
    Goodridge brake lines
    TT pedals
    N249 bypass
    Finally back on the road, have a HUGE list of mods and things to do now!
    Haglos's Avatar
    jabba mapped
    Mar 2008
    242
    lol it was getting dark but i will defo do it saturday morning
    beeitch's Avatar
    Mar 2006
    Madrid, SPAiN
    64
    Haglos check it up on heated fuses, see car manual for further details. :D
    27,126
    That doesnt mean anything, cause fuses are used for different options, its not neccessarily one fuse means one component, there are a number of systems that share fuses to receive power, now it maybe there's a fuse there but could be for another component, only surefire way is to remove seats
    Haglos's Avatar
    jabba mapped
    Mar 2008
    242
    yeah i have defo got to remove the seat there is a few more plugs underneath but i assume that there for the electric seat but today i took the side pannel of lifted the carpet up and i saw 1 loom but i checked the wire colours on the heated seats controls and they was not the same so i think it may be cut behind the dash but ill get the seats out and go form there
    27,126
    What you gotta realise is the wires that you see in the dash dont neccessarily go to the seats directly, they could be going to other modules on car 1st & fusebox then other coloured wires go from those locations to the floor looms, elsawin will shine the light on that one, so dont think its been cut in dash, I reckon all will be revealed when seat lifted out.
    Haglos's Avatar
    jabba mapped
    Mar 2008
    242
    yeah i noticed that when i had the centre console out it went into 1 big loom. with elsawin wat do i have to do never heard of him do i have to pay for a dvd or something?
    27,126
    PM me & I can enlighten you.
