Volks AutosMonster Motorsport
Results 1 to 30 of 30
    Aug 2007
    Thumbs down haldex not working no faults
    The problem im having with my 02 s3 four wheel drive dosen't seem to cut in, no faults shown or lights on dash has been hooked up to vagcom they tell me its ok, any ideas on what it could be?
    Smoothe
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    What have you done to test it?
    thegoal007's Avatar
    Another S3 owner....
    Apr 2008
    surrey
    729
    Additionally what was the incident that made you think this ?
    S3BLX's Avatar
    Dec 2008
    337
    mine doesn't seem to work either. just been on some snow and front wheels spinning away in 2nd back wheels wern't doing anything car just wasn't moving????????????? Please HELP?????????????????
    IF IN DOUBT......FLAT OUT!!!!
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    When i first got my car my Haldex seemed to not work either as when it was wet out it would spin the front wheels if i tried to pull away fast.
    I checked it furthur by using a grassy field at work and tried to spin the wheels while a mate watched and the back wheels did not move.
    If i remember right there is a fuse that governs the haldex so that would be the first thing to check.
    I had to go down the replacement Haldex controller and was lucky to get a second hand one for 40 and had it fitted locally. Since then hardly any wheelspin in the wet plus it was all good in the snow too.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    Apr 2004
    12,520
    I tested ours by clicking the handbrake one notch to bring the light on the dash, it was wheelspin city. Then dropped the handbrake and tried again and she gripped fine. Sounds like ours works a treat , and the test is an easy one
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,272
    Yeah check the fuse first. This is the fuse the rolling road guys pull if they dont have a 4-wheel drive rolling road. The owners manual should show you what number it is on the fuse board.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    S3BLX's Avatar
    Dec 2008
    337
    cheers. i shall try the fuse first. any ideas what the fuse will be named? and dont say frank, lol
    S3BLX's Avatar
    Dec 2008
    337
    i cant see one that stands out to be the right fuse.
    S3 Paul's Avatar
    Oct 2006
    2,764
    Nick,
    haveyou vag com'd your car?
    If there is no power to the haldex im sure the light comes on the dash...
    Mine with the esp turned off... grips and wants to hang its arse out in the snow so im sure its working.
    Noggy Blue 2001 S3
    S3BLX's Avatar
    Dec 2008
    337
    Quote Originally Posted by S3 Paul View Post
    Nick,
    Mine is crap in the snow. not vag com'd it, where could i get this done?
    S3 Paul's Avatar
    Oct 2006
    2,764
    At my house... lol ive got it on both laptops.
    i think it checks the haldex unit for faults.
    Mine does... let me know mate, I will check for fault codes
    Noggy Blue 2001 S3
    S3BLX's Avatar
    Dec 2008
    337
    Nice one mate your a star, when will you be in? i'll pm you my mob number. cheers dude.
    Whoever does not try, does not learn.
    Feb 2004
    Surrey
    192
    I thought mine wasn’t working either, had to read the manual and they mentioned something about driving below 40kph for the system to work. Also, Hadlex needs oil to engage the wet multi-plate clutch system, check ABS sensors too.
    Audi S3 (52) 265bhp Revo Stage 1
    j555pre's Avatar
    6
    I have the same problem too. Definately no 4wd. I've heard it can be the handbrake sensor that is still telling the car it is on when it isn't. I just changed the haldex oil and i think mine has been run dryish!!! I had it vagcomed and the fault read intermitent mechanical failure. So i think mines goosed. I tried the 5amp fuse for the haldex and that is fine aswell. Any thoughts? Also anyone local to burnley or halifax with vag com out there so i can get the hanbrake switch checked?
    Dennis Moeller's Avatar
    Jan 2007
    NorWay
    442
    Quote Originally Posted by rraghvani View Post
    I thought mine wasnt working either, had to read the manual and they mentioned something about driving below 40kph for the system to work. Also, Hadlex needs oil to engage the wet multi-plate clutch system, check ABS sensors too.
    This is not true...definately works even when driving more than 40km per hour...I have the rear wheels break loose in snow and on wet tarmac (winter wonderland in Norway) in both third and fourth gear when going waaaay past 40 km per hour...
    So something else is wrong with your system...
    My old car.. Still miss the lil rocket :-)
    Remapped Stage II - Forge FMIC - Dahlb�ck Intake - K&N - DieselGeek ShortShift - Phenolic - Powerflex Dogbone - Rial Daytona Race 8.5x18" ET30 - Forge Tiebars - Bilstein B8 - H&R 25mm - R32 rear ARB - H&R 20mm Spacers - EBC Discs - Red Stuff pads
    ______________________________________________
    NO ONE EVER REALLY DIED
    barters3's Avatar
    May 2008
    440
    not sure if its any help but i had a rumbling noise when i was pulling out of junctions, i changed the haldex oil and it stopped, must have been running with low oil, howeverit didnt stop the 4 wheel drive operation.
    S3BLX's Avatar
    Dec 2008
    337
    I went to s3 pauls earlier, he hooked my car up to vag com and it came up with intermitant haldex malfunction, caused by clutch switch......correct me if i'm wrong paul, lol. anyways he cleared it and didn't seem to come back. so went for a drive........................I now have 4wd wayhey!!!! Brilliant. Just wait and see if it throw the fault code again, hopefully not. Cheers again paul
    j555pre's Avatar
    6
    I hope mines as easy to fix!
    j555pre's Avatar
    6
    That sounds alot like my fault code but mine said mechanical fault?
    S3BLX's Avatar
    Dec 2008
    337
    mine could have been that, dunno paul would be best to ask. hope you get it sorted.
    Dec 2008
    Finland
    42
    The pumps usually break on gen.1 haldex sooner or later, unfortunately quite often sooner.
    Vag-com will not give a fault code on this problem, the only way to test it is by measuring the resistance in the pump. Don't know if this is a common problem over there, but up here the Haldex is used way more because of the snow. Unfortunately I've heard lots of ppl having this problem, and it's not a cheap part.
    Let's hope anyway that it's something else than this.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,232
    Bit of a revival but dont think my haldex is working, i dont have vagcom to check it so how do i use the handbrake method, do i just pull it up one click then try and drive or what!
    barters3's Avatar
    May 2008
    440
    Just pull the handbrake up one click, if you should be able to light the front wheels up. I had a leaking haldex pump so if replaced it with a second hand one. Since then my four wheel drive has not been working. I'm going to check the fuse, then vagcom it, then last resort I'm going to change the pump again. I didn't realize that it was common for the pump to fail
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,232
    Seems everything is a common fault on the s3.
    barters3's Avatar
    May 2008
    440
    Quote Originally Posted by Pirrex View Post
    do you check the resistance by putting a multimeter on the terminals? if so would i use the ohms setting and what reading should i look for?
    Hope you can help, im rubish with anything electrical....
  28. #27
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,232
    I need to know how to check it properly, just tried the handbrake way but just drove like normal.
    So how else do check it?
  29. #28
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,232
    Im pretty certain about the answer to the question im about to ask but just want to make sure.
    Would a knackered/faulty haldex cause me tobe down on power?
  30. #29
    Jun 2009
    12
    If its constantly stuck in 4x4 like mine then yes you will be down on power, its just occured to me that if you remove the fuse then we should have only front wheel drive again.
    Regards
    Rob
  31. #30
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,232
    No mine isnt stuck in 4x4 drive, my 4x4 drive just doesnt work by the looks of it.
