Chris NottJMB Retrofits
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Strange sound under acceleration - any ideas?
    I'm getting a strange noise when accelerating, the best way I can describe it is like a "gurgle" noise coming from the engine
    I've scanned the ECU and got the following error code but can't track it down on the Ross tech wiki
    Code 17535 (P1127-35-10) System Too Rich - Bank 1
    After seeing this, my inititial thought was the MAF messing up the fuel ratio but I'm not sure if that would account for the sound it's making so I was thinking it could also be the OEM recirc valve playing up.
    It's on a 2000 AMK S3 - no engine mods
    Anyone ever had this before? - Any ideas what's causing it?
    Any ideas would be appreciated
    Mike
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    Sep 2005
    uk
    80
    i think i have a similar problem to you, but i haven't had it checked on vagcom. i get a very low noise when starting to accelerate over 3000rpms. i thought it may be nothing but i am interested in what you find... mine is 2001, standard spec.
