Badger5EM Tuning
Results 1 to 12 of 12
    peakey's Avatar
    Sep 2007
    BIRMINGHAM
    249
    another dump valve question
    I got myself one as everyone else has one just wondered what is the point of a dump valve. To be honest the one i have dont dump just makes a little woosh noise in the glove box
    Andy_S3's Avatar
    May 2007
    Teesside
    719
    I think the reason most people buy a diverter valve on here is that the Bosch OEM often breaks as the quality isnt the best. In terms of noise youll never get a loud whooshing noise unless its broken! Best thing you can do for the noise is fit a Forge Split-R and an aftermarket panel filter.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Dump valve / diverter valve prevents the turbo stalling when the throttle is closed.
    Jan 2009
    Currently living in Germany.
    9
    I just got an induction kit and it makes the standard one sound more prominent
    peakey's Avatar
    Sep 2007
    BIRMINGHAM
    249
    Quote Originally Posted by djakster View Post
    whats a split r
    Andy_S3's Avatar
    May 2007
    Teesside
    719
    The same as a Forge 007p Diverter except you can adjust the amount of air thats recirculated and how much gets dumped out.
    Keefo's Avatar
    Jan 2009
    46
    i thought VAG cars didnt like dump valves much...
    If i was going to get one that was simple to fit, and made abit more noice could anyone recomend one??
    Oct 2006
    Manchester
    724
    http://www.forgemotorsport.co.uk/con...duct=FMDVSPLTR
    That is the SpliR valve
    The only dump valve that can be fitted to the 1.8T and Forge have had this in for development for ages!!!!
    But is the only one that will not give you the warning light and issues
    Sarah
    afcjay's Avatar
    Aug 2008
    426
    so do these actually work without causing any issues on all 1.8T engines?
    3dr Dolphin Grey Audi A3 2.0 TDI S-Line
    Andy_S3's Avatar
    May 2007
    Teesside
    719
    Have had one on mine for a few months with no problems so far, as long as its adjusted properly it should work fine.
    afcjay's Avatar
    Aug 2008
    426
    are they easy to set up and how loud are they?
    Andy_S3's Avatar
    May 2007
    Teesside
    719
    According to your sig you already have a 007P? I had one of them on my old 1.8T Quattro and the difference in noise between the two isnt that great, so if its just noise youre after, I wouldnt bother forking out the extra pennies.
