AH FabricationsEM Tuning
Results 1 to 16 of 16
    V.I.P_UAE's Avatar
    Jan 2009
    why do I have wastegate flutter/chatter on standard car?
    As above, i have slight wastegate chatter, the car is not modified in any way at all, its getting louder by the day, yeah sounds wicked but im sure it should not do that, unless someone has broken into my garage and fitted something while I was asleep lol..
    Anyone know what could cause this? It dosent seem to be down on power?
    Tastyterrier's Avatar
    Monkey Trainer
    Jul 2003
    Staffordshire
    341
    Probably a knacked DV. The standard Bosch ones don't last a long time.
    A3 1.8TQS: Supersport Springs and Shocks, Xenons, BMC Filter, 18" OEM TTV6's, Bailey DV, N75J and Phase 1 Custom Code.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,067
    yup, it's a split diaphram in the DV, replace it with a forge if you don't want it to happen again!
    Also, as per the thread on here the other day, it's not anything to do with the wastegate at all, that's a commonly made mistake.
    It's actually compressor stall, as the pressurised air inside the system hasn't been vented through the DV, because it's not openning.
    nickrex's Avatar
    Oct 2008
    45
    Yeah. Definately a knackered dump valve. Mine did the same a couple of months ago. They're not expensive and a 10 minute job to fit.
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Diverter Valve, Not dump valve.
    The two are very different in operation.
    But yeah, as above. Yours is broken.
    <Insert meaningless geeky specs here>
    V.I.P_UAE's Avatar
    Jan 2009
    will it lose power through this, ive only had it 3 weeks, maybe it will be quicker after I change??
    V.I.P_UAE's Avatar
    Jan 2009
    Quote Originally Posted by Dave_Bayern View Post
    is a diverter valve different to a dumpvalve? where is this located? thnx
    themanthatcan's Avatar
    Mar 2008
    Southampton
    665
    Yeah it'll cause the car to feel slower and (the way I understand it) also bring about premature failure of your turbo if not sorted out quickly. When you come off boost (ie when changing gear) the pressurised air is travelling back towards the turbo, causing the blades to slow down. When you come back on the power the turbo has to spool up all over again. This will affect performance.
    Andy
    2001 S3 AMK in black - Ambient lighting kit and Aero wipers.
    Is it wrong to love your car more than your girlfriend? - When you no longer have a girlfriend it's fine!
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,985
    just buy a new one from Audi, cost nearly 20..... if your not bothered about the shiney Forge type then this will suit just fine.... unless you want to spend 80-90
    Xbox 360 gamer ID : Timffy
    Black FZ6 - Turbo car 'slapper'
    V.I.P_UAE's Avatar
    Jan 2009
    Quote Originally Posted by 1animal1 View Post
    Dumpvalve or Diverter valve??? what do i need?
    thanks
    Oliver
    Andy_S3's Avatar
    May 2007
    Teesside
    719
    Diverter valve matey
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Simple.
    Dump valve - dumps air into the atmosphere
    Diverter Valve - diverts air back into the intake system
    No VAG Car has a dump valve
    V.I.P_UAE's Avatar
    Jan 2009
    Excellent, does anyone know the part number?
    oliver
    SDO
    153
    I have this but mines sounds more like i've got a atmospheric DV on, i haven't got a forge diverter valve would having a panel filter do anything
    A3 1.8T - S3 Black Leather interior, Pipercross panel filter, CC stage 1 remap, Vr6 clutch, G60 flywheel
    Andy_S3's Avatar
    May 2007
    Teesside
    719
    A panel filter will increase the noise from the diverter valve slightly.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,067
    the standard DV should sound a little like an atmospheric DV, the sound you hear is just comming from the air filter, and it's nothing to worry about.
