Sky InsuranceVolks Autos
Results 1 to 11 of 11
    Oct 2008
    24
    Exclamation A3 8L Quattro gearbox removal please HELP
    Hi i am trying to remove the gearbox on my 1999 Quattro but i wont come away from the engine i can seperate it about 1cm then it springs back and i can find anything holding it in. do i need to fully remove the engine. ideas would be greatly appriciated thanks in advance
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    sounds like you have either missed a bolt or its stuck on a dowl you really need to make sure that there are definantly no left over bolts then if not you will have to be a bit more persuasive with the removal of the box around the area where its stuck on
    Oct 2008
    24
    Thanks very much for your help mate at least someone is helpful on this site unlike when nobody replied to other threads i have posted.
    807
    This place is very helpful. Sounds like a bit of a slating to people who havent replied.
    If body replies to a help thread it will usually be because they have no idea or it has been covered loads before. But you will usually get a point in the right direction.
    People who do know an answer to a specific question dont always live on here so be persistent and you will usually get an answer.
    good luck
    Oct 2008
    24
    Hi everyone i dont mean to slate the site, its an awsome site but its a little frustrating when you need help but no one replies Thanks in advance James
    h100vw's Avatar
    Aug 2006
    Down South, next stop Antarctica
    215
    Probably not many folk have done a Quattro box, which accounts for the lack of answers.
    Most clutch threads I have seen have mentioned going to a workshop.
    Gavin
    s3ollie's Avatar
    Jan 2007
    749
    get your self elsawin, this will give you step by step guides to its removal
    8P S3
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    Quote Originally Posted by A3Quattro1985 View Post
    i dont mean to be rude here but if your having no luck on here you would be better off spending the time checking that you have done everything needed to get the gear box free of the block, there arnet any hidden bolts if thats the awnser you want and its hard to diagnose your problem with out having the car to look at, good luck mate but its just persistance required with this one
    807
    Yep.. elsawin helps no end with everything when working on your car.
    Oct 2008
    24
    Hi, everyone i have just replaced the 5 speed with a 6 speed box i cant get reverse very well and to get 1st i have to push down to were reverse normally is and 2nd is also hard to get aswell i have been told to change the gear selector is this under the gearstick as i am still using the original. i want to say thanks for your help before we ended up taking the whole engine out and then we found there was a bracket that cant be seen easily with the engine in.
    I really hope i havent upset people in the site as it is a brilliant site
    James
    807
    Good stuff.. well done on getting back will probably help some other people out who have the same probs as you
