Volks AutosChris Nott
    S3-Oski's Avatar
    Nov 2008
    Essex
    480
    Does anyone know?
    Hi all i just had my car up on a ramp quickly to check for an exhaust leak because i noticed my car sounds a bit blowly, but could not see anything underneath, will check again at weekend beacuse something is not right,
    But i was having a good look underneath and i noticed that the black metal thick pipe what has an intercooler each end, If your standing underneath the car the drivers side of the pipe has another bit of pipe like a smaller diameter stubby bit which looked like it is capped off,
    This pipe which joins the main intercooler pipe on the weld had like a PEA SIZED HOLE, but looked quite a neat hole is this meant to be there, i thought that the pipes in had to be air tight etc? If not it could exaplin a few things, sorry for the essay hope it makes sense, thansk Oski
    S£'s Avatar
    Mar 2008
    Suffolk
    669
    Absolutely yes it has to be air tight!!
    S3-Oski's Avatar
    Nov 2008
    Essex
    480
    ok thanks will have another look weekend it looks like the hole is quite neat i thought it might be there for a reason and the pipe is good condtion no rust etc, hmmmmmmm
