Results 1 to 13 of 13
Thread: New Display
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    New Display
    Im about to finaly pick the s3 upbut the center clocks are quite badly messed up so want to get them fixed as soon as, now audis quoted me over Ł1000and thought not achance so looking at other alternatives and saw these two, does anyone know if either will fit
    http://shop.ebay.co.uk/items/_W0QQ_n...romZR40QQ_mdoZ
    cheers
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,089
    they will fit but your car wont start.... clocks are coded to your ecu and ignition key... you can get them reprogrammed but it aint cheap
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    any idea how much? id also have to get the mileage set to what my car is wont i!
    807
    They can be coded and miles fixed by someone with vag-tacho or vag k+can commander.
    But its quite a lot of hassle.
    send your cluster here: http://www.clusterrepairsuk.co.uk/repair-list/audi/a3/
    seems to be quite cheap... i think they also advertised on ebay and someone on this forum vouched for them.
    Ive been toying with the idea of getting mine sorted but they aint bad enough at the mo.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    cheers pal, the only problem is i cant afford tobe without my car due to work etc so these arent really an option and the companys ive tried wont travel to yorkshire (most are based in london). anyone know of a company in the yorkshire area capable of doing this?
    807
    Yeah thats the only downside to this fix. Unless you worked it around a holiday or something by sending it off when you dont need the car?
    Im based in leeds currently so would be interested as to how you get on.
    http://volksworks.net/about.htm - This guy in leeds should be able to code the clocks for you, ive used them to read my immobiliser code before and he knows his stuff.
    The problem may be that a second hand unit from ebay will most likely have the same problem or will have in the near future.
    Inerested to see how you get on though
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    ok so phoned audi up and they said if i get the clocks theyll fit them for an hours labour (Ł80), so bargain only down side is they wont change the mileage on the new unit because its second hand so just trying to find someone who can do that now but audi told me its impossible, didnt explain why so ill see what i can find and let you know
    807
    "vag tacho" or "vag k + can commander" (ebay very cheap) will be able to change the milage.
    tbh i think thats a ripoff to fit clocks but i suppose you are getting them to code your keys etc so spose thats ok
    I have a vag tacho copy but have never used it for this.
    member "S3mad" also has a vag-tacho i beleve his is official version.
    but as i said a second hand unit will get this problem anyway at some point if it hasnt got the problem already
    btw audi wont have the tools to change the mileage
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    would i have to change the mileage before or after i change the clocks? btw cheers for the help mate
    Khufu's Avatar
    West coast of Scotland
    5,693
    IIRC you change the mileage after its fitted. I have a cluster in my cupboard that has no miles on it so can be set to any mileage. I bought it for my old A3 as I didn't have the DIS but as my car was the pre-facelift and the cluster wasn't I couldn't encode the immobiliser.
    807
    Yep as Khufu said do it after you have fitted them. And tbh you only need to make sure you get it done before the next MOT i think to keep all the history in line. Just make sure you keep track of you mileage .
    But a 0 (or very very low) milage cluster will be able to be coded by any normal vag-com (vcds) as far as i know. But once its set you cant change it again except with the tools i mentioned above.
    Apr 2008
    17
    I have a contact that can re-code the replacement set of clocks in and correct the milage for you. He has done a set for me and everything works perfectly.
    Another bonus is that he isn't too far from Yorkshire - drop me a OM if you want his contact details. I believe he will also travel if you cover his costs etc or you can take your car to his premisis.
    Tim
    Khufu's Avatar
    5,693
    I'm sure the mileage can be correct only if its less than 100 using convential methods. Im sure however as stated above, there are other leads that can correct the mileage no matter what its at.
