Chris NottVolks Autos
    Feb 2003
    So Paulo, Brazil
    34
    Does OEM radio affects ECU malfunction?
    I am used to turn on my Simphony radio everytime I drive. Recently my ECU had problem (had changed) and would like to know if someone knows about Audi A3's electronics. I suspect that my radio "could" influence the ECU, because, some days before ECU failure, my CD stoped several times, like muting for 3 or 4 seconds. This symptom occured everytime I increase the volume.
    Oct 2003
    396
    Re: Does OEM radio affects ECU malfunction?
    The Symphony does share data with the CAN Bus which is also integrated with the ECU. So it is conceivable that an ECU fault could send duff data on the CAN bus which might confuse the Symphony headunit. the other way around I guess is possible also but if your ECU was faulty then it was probably the culprit.
    Feb 2003
    So Paulo, Brazil
    34
    That's an important information to me. But in the other hand, is it possible that the usage of symphony in a high volume for a long period could damage (overheat some component on ECU) the ECU?
    Oct 2003
    396
    Absolutely not, the ECU is not located anywhere near the Symphony headunit. The only thing you are likely to damage by playing very loud music are your ears (or speakers if sound is badly distorted).
