Chris NottSky Insurance
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    A3 1.8TQS Extreme cold Starting problem
    Ok here it is, i have found the A3 will not spark,It seems to only be when the temp overnight has been around 0 degrees. The lights go out on the dash inc the immo light but it will not fire, Upon a retry the ESP light will stay on and give me the following code:
    Control Module Part Number: 1C0 907 379 F
    Component and/or Version: ESP ALLRAD MK60 0104
    Software Coding: 0023046
    Work Shop Code: WSC 06435
    1 Fault Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    The engine ECU doesnt have code showing but the ABS/ESP module does if i clear it the car will start, i mean WTF???
    I have had the ECU out and dried it overnight in case it was moisture, then used a cotton bud and leccy cleaner on the terminals to ensure they are clean, also sprayed the connectors on the car wiring to ensure the same.
    Anyone have any ideas????
    Its fraustrating at best having to take the lappy out for every cold journey just in case.
    Apr 2004
    12,523
    WOW !! a problem no one has had before then. I am the Pioneer !!! lol
    h100vw's Avatar
    Aug 2006
    Down South, next stop Antarctica
    215
    Does it turn over? Or does the dash just go blank?
    Gavin
    Apr 2004
    12,523
    She will turn over fine, but no start due to no spark
