Chris NottAH Fabrications
Results 1 to 15 of 15
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    Doors open read out on DIS.
    I dont think this is meant to happen!
    When I open the drivers door my DIS shows that the drivers door is open. But If I have my drivers door shut and open the passenger door is shows that both doors are open!
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    omegadirective's Avatar
    Oct 2008
    Oxfordshire
    134
    It's probably the contact switch on the door locks., or the contact circuit. I've just had one replaced at Audi for 170, and that was a good deal. Originally I got quoted over 220 as the door trim has to come off.
    27,126
    Does it still show as open when the drivers is shut without passengers open & do the lights go out normally?
    Westy's Avatar
    Dec 2008
    17,283
    Not too sure what you mean?
    When both doors are shut the dis shows them shut. When the drivers is open on its own the dis shows just the drivers door open. If only the passenger door is open the dis shows both doors open!
    S3 Build Thread
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,095
    Do you have any probs with the Boot, or is it just the doors??
    It could be the microswitch thats causing a problem, there is a common fault on the S3, where in the heat it thinkst that the drivers door is open, i know thats slightly different to what you are having, but it could be something along those lines causing the problem....
    Westy's Avatar
    Dec 2008
    17,283
    The boot reports back fine. HAs anyone changed a micro switch themselves cos I dont like the sound of 200 from Audi.
    S3 Build Thread
    Nov 2004
    103
    Hi there, I had a similar problem a while back - drivers door showing a open intermittently - also meant the alarm wouldnt set. I think its the micro switch and there was a link to replacing the microswitch - looked a bit fiddly so I bought the whole latch assembly from Audi for about 40 and fitted it myself. There's a link on here somewhere about how to do this which I followed - took a few hours but saved me a few quid.
    Nov 2004
    103
    few links about but I think the one I used has gone.
    faulty drivers door catch / switch
    Open door indicator won't turn off?!
    Westy's Avatar
    Dec 2008
    17,283
    Thanks, I take a look for the guide cos my alarm doesn't arm either so it may be the same issue you had. How did you diagnose which door switch needed replacing cos mine only has issues when opening the passenger door but its the drivers door that displays as open too!!!
    S3 Build Thread
    Nilz's Avatar
    Apr 2006
    10,095
    I just sprayed inside the keyhole with WD40 and it did the trick....might be worth a go....
    Nov 2004
    103
    Sounds odd that both doors are causing a problem - mine was definately only the drivers side. Wish I could find that link for you - there were pictures in the guide.
    Westy's Avatar
    Dec 2008
    17,283
    I'll give the WD40 trick ago later that seems like the cheapest/easiest/fastest thing to try at the moment. I'll let you know how it goes.
    S3 Build Thread
    Nilz's Avatar
    Apr 2006
    10,095
    No worries, let us know....
    Westy's Avatar
    Dec 2008
    17,283
    Ok the WD40 didn't do a thing except get rid of an annoying squeak I had on the passenger door handle. Oh well I'll get the doors apart at some point.
    S3 Build Thread
    Nilz's Avatar
    Apr 2006
    10,095
    LOL...soz dude, at least you got rid of the squeak
