Chris NottEM Tuning
Results 1 to 30 of 30
    reptor245's Avatar
    Jan 2009
    Torquay
    1,144
    A3 Engine Coolant Sensor G62?
    hey guys, ive run Vag-Com today and my 1.8T and it came up with
    16500/P0116/000278 - Engine Coolant Temp. Sensor (G62): Implausible Signal
    Possible Symptoms
    Starting the engine when engine is warmish or warm, idle rpm immediately is 1200 - 3000 rpm.
    Diesel: an indication is extreme long time burning time of the glow indication light.
    With all engine temperatures seldom idle rpm will vary between 900 - 1000 rpm.
    With engine warm (90 C) the engine temperature suddenly drops (70 C) and slowly comes back to 90 C.
    Possible Causes
    Wiring and/or connections faulty
    Engine Coolant Sensor (G62) faulty
    other than the stealers, were can i get a new green type sendor from? thanks in advance
    Oct 2008
    15
    you can get it from GSF or Eurocarparts but the delaers will prob only be about 20/25 quid so i would go there and get the genuine part tbh!!
    Andy
    reptor245's Avatar
    Jan 2009
    Torquay
    1,144
    Quote Originally Posted by andyg0141 View Post
    Andy
    aha oks, might give them a ring tomo to get a price incase. ive email GSF too :-)
    beeitch's Avatar
    Mar 2006
    Madrid, SPAiN
    64
    Easy to remove, and cheap to buy :D
    2002 A3 1.9 TDi QUATTRO S-LINE AVUS SILVER with full OEM Bodykit
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    murraysdirect.co.uk
    ^^ In my opinion
    dantdi's Avatar
    Feb 2008
    kent
    511
    Coolant Temp Sensor for 2004 2.0tdi is 35 quid from audi. Brought one b4 xmas
    hope this helps.
    reptor245's Avatar
    Jan 2009
    Torquay
    1,144
    Quote Originally Posted by abdus View Post
    murraysdirect.co.uk
    nice one. just got an email back and will cost
    A new temperature sensor is 12.77 plus a seal 0.56. We currently have stock available for immediate despatch. P&P [1st class recorded] is 3.16.
    bargain.
    Feb 2008
    10
    Sorry to bring this back up.
    Mine is coming up with the same error - G62 Implausable Signal.
    Ive changed the sensor and still no luck - what else can i check? Mr_v suggested buying the whole housing as sometimes it can get cracked but i want to know if there are cheaper things i can check first? Cheers guys
    Feb 2008
    10
    Quote Originally Posted by kaos_king View Post
    It turned out that it was a loose connection to the G62 sensor
    russelj80's Avatar
    Jul 2010
    Scotland, PH3
    25
    where exactly is this sensor on the car? mine has gone too apparently. same fault code on the vagcom and everything!!
    Madeley's Avatar
    Jun 2010
    Telford
    125
    Just above the gearbox on a coolant pipe.
    S3 2000 AMK car with a APY engine, minge blue, rs6 alloys and Revo'd by Badger5
    Feb 2009
    69
    Has anyone got a pic of where this sensor is, need to change mine in a couple hours.
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    You really can't miss it. If you follow the top radiator hose back to where it splits into a Y pipe, it's just to the left of that in a coolant pipe. Single clip, undo the wiring connector and pull it out
    russelj80's Avatar
    Jul 2010
    Scotland, PH3
    25
    photo would be nice! ive changed 2 sensors in that area and really struggling to see where this one goes!
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by russelj80 View Post
    This is the best I can find on the web. This is looking at the engine side on, with the air box removed, from the passenger side.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    talentwalsh's Avatar
    May 2010
    Galway
    139
    Dont forget to release the pressure before changing to avoid wet socks!
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by talentwalsh View Post
    lol, or a feckin hot face....
    I'd normally recommend doing it after the engine has completely cooled.
    Homer Simpson
    russelj80's Avatar
    Jul 2010
    Scotland, PH3
    25
    nice photo mate!! thanks. This could be promising!!
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    No worries. Looking at the photo, the TIP is on the right, and the battery on the left.
    Homer Simpson
    russelj80's Avatar
    Jul 2010
    Scotland, PH3
    25
    got the air box out just now thinking id see something more obvious. looking at the pic tho ive already changed that sensor. the one i have wouldnt fit that 4pin connection anyway. unless audi gave me the wrong sensor here i dunno? . . im only wanting a temp reading on my dashboard i assume it is just a sensor somewhere?
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Its deffo that one dude. Must have the the wrong one..
    Homer Simpson
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    Ive just changed the same sensor but i think the cars air locked now.
    Can i remove the expansion tank lid and squeez the pipes or will that suck more air in?
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    No, that will help.
    Best thing is to leave the cap off and give the engine a rev to fast idle for a min or two. That has always cleared any air locks I've had.
    Homer Simpson
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    So i can leave the cap off and start the engine? fast idle been around 2500rpm?
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Yep, have the heaters in the car on max temp and full whack as well.
    Homer Simpson
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    Goes outside to try now , cheers welly.
  28. #27
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    implausible signal can also be caused by a faulty thermostat.
    TD5 Land Rover Defender build
  29. #28
    russelj80's Avatar
    Jul 2010
    Scotland, PH3
    25
    ive changed the thermostat mate. so its either the sensor ive changed is faulty or the connection is faulty or even still, there is a problem with the dashboard itself!!?
  30. #29
    Dec 2009
    Warrington
    27
    I was getting a regular 17704 code off the LG along with a (white) smokey exhaust and a few hot start problems which was solved by replacing the G62.
    I bought the sensor, clip and o-ring from ECP for 18 and thanx to welly for showing us where the sensor is located, it's taken about 2mins to replace. Happy now
    Reversed 007 = Turbo Qweef
  31. #30
    Dec 2009
    Warrington
    27
