Badger5JMB Retrofits
Results 1 to 7 of 7
    Forever going forward!
    Dec 2007
    Bridgend, South Wales.
    20
    S3 problem..... please help!
    Hey Guys,
    I have a 00' S3 (facelift) with 97k on the clock. For the past few days I have had problems with it.
    Car idles normally and drives ok until it comes on boost. When the turbo is supposed to come in it starts mis-firing and has zero power.
    The engine management light flashes orange.
    Recently had both lambda sensors replaced (audi parts)
    Had it scanned with an RAC fault code reader and it came up with :-
    Mis-fire detected on cylinder 4
    Any idea what this could be?
    Could it be spark plugs? Faulty Coil Pack? Or something else?
    Can someone point me to where the coil packs are located on the S3 engine please (pics would be great)
    Any help would be gratefully recieved.
    Many Thanks, Graham.
    Dec 2007
    20
    Ok Guys I have found the coil packs.
    Does anyone know which is cylinder 4? Standing in front of the car would number 1 be on the far left and number 4 on the far right?
    Please help.... Cheers, Graham.
    S3 Paul's Avatar
    Oct 2006
    2,764
    How do boss. cylinder 4 is the gear box end... to the right as you look at the engine.
    Best way to find out if its a coil pack ... unplug coil 4 and fire the car up. it sould make no diffrence to how the car runs... they are about 27 pound new so it nothing major if its that.
    Noggy Blue 2001 S3
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    and dont buy the cheap ones is you go to GSF get genuine vag ones GSF do them for a couple of quid less than audi but any audi vw dealer will have them in stock. the 2 on the rhs are slightly harder to do than 1 and 2 as theres a bit to remove to get to them but not a bad job
    red to red black to black blue to bits
    Dec 2007
    20
    Hey Guys,
    Thanks for the help. I changed all 4 as a precaution and everything is now great.
    car actually feels quicker than before the coil pack went so I dont think its been running right for a while before it actually failed.
    Many Thanks again.
    27,113
    Yeah its amazing how a change in packs & plugs works wonders, I had a knackered plug the ceramic had cracked, changed it up & was perfect.
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Just changed mine as well and it does feel alot smoother, gload you got it all sorted mate.
