Chris NottBadger5
Results 1 to 12 of 12
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    Front wipers - help!
    Dont laugh! I feel like a total prat having to post this question, but HOW THE FECK DO I GET THE FRONT WIPERS ARMS OFF!!!!!!!!!!!
    ..... they currently appear to be welded to the motor splines - any usefull advice greatly appreciated.
    Cheers [img]/ubbthreads/images/graemlins/blush2.gif[/img]
    oh and b4 its said, yes i have removed the nuts, and tried beating the buggers with a hammer!
    North East
    30
    Re: Front wipers - help!
    The wiper arms sit on splined tapers. Remove the nuts and rock the arms backwards and forwards, i.e pull towards engine bay, push towards windscreen and this should release them from the splines.
    Woodster's Avatar
    Welcome to my world...
    Dec 2003
    Mighty Mighty Yorkshire
    83
    I've just changed mine, they're a complete sh!t to get off!
    I used a small g-clamp, if you hook the bottom of the clamp behind the wiper arm and the hold the top on the spline and tighten the clamp they eventually come off.
    Worked for me
    Rich
    Drill's Avatar
    Land of Good Beer, and better Roads :-p
    928
    I used the same method as Woody, got a pipe wrench, hooked one jaw under the base of the wiper blade, the other on top of the spline/bolt and SQUEEZED!!!! [img]/ubbthreads/images/graemlins/burningmad.gif[/img] (And cursed, then squeezed some more. Cursed some more. Left.... cursing. Came back....) and they popped right off [img]/ubbthreads/images/graemlins/angel.gif[/img]
    [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Middlesex
    141
    It took me about 20 seconds to remove both wipers when I changed them over a month or so ago. I found that the pressure that they exert on the window means that they dont sit square on the spline, lifting the arm up a bit allowed it to line up and they slid off. No clamps, tools, swearing needed other than for getting the nut off [img]/ubbthreads/images/graemlins/smile.gif[/img]
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    cheers guys, invested in some WD40 aswell.
    Will be giving it another go this evening [img]/ubbthreads/images/graemlins/wink.gif[/img]
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    OK, I have squirted liberally with WD40. I've had a strap under the arm and with my handy held pulling I've hit and hit and hit - guess what, nada, nothing, zip!!!
    AGHHHH!
    looks like I am gonna be cutting the BSTARDS off, less drastic solutions greatly accepted b4 the weekend.
    How can changing wiper be this difficult - story of my modding life [img]/ubbthreads/images/graemlins/frown.gif[/img]
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    cut both the buggers off (dremel), new wipers fitted
    HURRAH [img]/ubbthreads/images/graemlins/smile.gif[/img]
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,435
    LOL
    recomdos's Avatar
    Feb 2004
    North East
    988
    i need one of them dremels
    Woodster's Avatar
    Dec 2003
    83
    me too, you can never have enough power tools!!
    Jan 2004
    15
    When I had my windscreen replaced, I noticed the guy slammed his hand down hard on the motor splines and then pulled the arms off straight away.....try that!
