Badger5Sky Insurance
Results 1 to 9 of 9
    Bucks
    1,038
    Strange noise - anybody got a clue !?
    When I lift off the accelerator I get this weird noise.
    It's hard to describe! It's a cross between a popping sort of noise, and the sort of noise a fan might make if it is catching something on the way round (but quickly).
    Only noticed it recently... any ideas ??
    Northern monkey
    168
    Re: Strange noise - anybody got a clue !?
    ive experinced this noise as well - sounds like its coming from behind the clocks ????????
    AL_B's Avatar
    Warrington, Northwest England
    1,564
    Jo you're right it is hard to describe. I can't make any sense of what you have just said. [img]/ubbthreads/images/graemlins/lol.gif[/img] [img]/ubbthreads/images/graemlins/laugh_roll.gif[/img]
    AL
    1,361
    Maybe it's the fan catching on something, hence the noise like the fan is catching on something? [img]/ubbthreads/images/graemlins/lol.gif[/img]
    Chepstow, South Wales
    620
    Not the dump valve is it?
    Bucks
    1,038
    Ha ha thanks guys !!!
    John said it might be the DV making normal noises (changed back to Bosch for various reasons) but I'm not sure - it's not a whooshing noise but it does tie in with the DV - i.e. it's when you lift off the accelerator while accelerating...
    I think the noise from behind the clocks (do you mean behind the air con etc.?) is the air conditioning pump - try turning it off and see if it still makes the noise?
    1,361
    If the DV chatters I think it could cause the sort of noise you describe, if you can think about the WRC cars the dump valves, which are much more vocal than a DV (and slightly different function), they chatter and wheeze when dumping the clutch....which sounds like you could have a softer version of it.....maybe. [img]/ubbthreads/images/graemlins/grin.gif[/img]
    Bucks
    1,038
    Maybe! It does sound like that asthatic wheezy rattle! Not cool !!!!
    AL_B's Avatar
    1,564
    If the noise is the chatter-type noise (like the rally cars) - your DV is buggered. I had this on my old A3 1.8T, DV was eventually replaced by the dealer, and no more chatter-noise afterwards.
    Jo, didn't you say your Bosch valve is a new one? Put your other valve back on, and see if the car still makes the noise, if it doesn't, you'll know its the Bosch valve thats f'd. Go on Jo, you can do it, its only a 10-min job to change the DV. [img]/ubbthreads/images/graemlins/grin.gif[/img]
    AL
