Volks AutosEM Tuning
    jays3's Avatar
    Jul 2008
    75
    headlight washer pump
    my passenger headlight washer pump is leaking anyone know what the part number is for this,
    S3 Paul's Avatar
    Oct 2006
    2,759
    Passenger washer pump?
    As far as im aware they are run from the same unit?
    Do you mean there is some times a leak from that side of the bumper?
    The water is piped from the pump ( screenwash bottle mounted) to a preasure valve that opens and pushes the light washer unit up when the windscreen washers have been on a couple of seconds. if you have a leak out of the light washer its self then it maybe the valve that leaking water through... if not i would check the pipe work itself.
    Noggy Blue 2001 S3
    jays3's Avatar
    Jul 2008
    75
    thats what i mean, i took the bumper off and its the pressure valve thats leaking the pipework is all fine, its only a little drip but its annoying me. can i just replace this one part.
