Sky InsuranceEM Tuning
Results 1 to 13 of 13
    V.I.P_UAE's Avatar
    Jan 2009
    Help... No Headlights !!!!
    Evening Chaps !!
    After picking up my Audi S3 late 00 Early 01 model today , and the Girlfreind told me they work grrr, I have found that I have no headlights, she seemed to think sidelight = headlight....The bulbs seem to be fine.
    Also when im driving very slow round there is a whine, what sounds like tired powersteering only when sat on the spot turning the steering wheel or driving over 30 its quite?? I thought the power steering would whine when stationary which it dosent.. everything else seems fine.,
    ill post some pics up in a couple of days when I get the matt black "fast and fourious" bonet and roof painted silver again
    Oh and one last thing how much do you guys pay for a 4 rings badge on grill from dealer?? and are they hard to remove? That is also Matt Black and I would like Silver.
    Any Ideas would be much appreciated.
    Reposted in correct section now.
    Nice Forum BTW..
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    welcome to the forum mate
    Is it both your dipped beam & main beams that are not working? - if so I'd check the fuse first (there's a fuse layout diagram in the handbook if my memory's correct). it'll be a lot cheaper than two new xenon headlights
    I'm not sure about the whine noise you mention - have you checked the power steering fluid's ok?
    as for the badge i think they will brobably cost a bit from a dealer maybe 30 quid or so (i'm not sure) but you can probably find them cheaper on vagparts
    good luck & get some pics up of your new car
    Mike
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    V.I.P_UAE's Avatar
    Jan 2009
    Quote Originally Posted by MikeA3 View Post
    Mike
    Thanks mike Ill check the fuse, any idea where the fuse box is?, im a total audi novice and would mine have xenons? It has the aluminium Wingmirrors and armrest and bose system, from my research this hould have xenon lights but i dont think it has? how would i know?
    Sorry for my such lack of knowlege on this car, only had it hours!
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,090
    Hey dude, all S3's come with Xenon as standard, so the car will defo have them on.
    Let us know how you get on.....
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Quote Originally Posted by V.I.P_UAE View Post
    not a problem - the fuse box is located on the drivers side part of the dash as you open the door, you'll see a rounded off triangular plastic cover on the end of the dash & it's behind this (the cover is held in place with three small metal clips so it should pop off farily easily)
    and as nilx posted above, - all S3's will have xenons
    S3 AMK
    V.I.P_UAE's Avatar
    Jan 2009
    Thanks guys, wicked forum... Will try this!!
    These problems im having have kinda took the shine off the honeymood period with the car.. Still, very nice car tho..
    V.I.P_UAE's Avatar
    Jan 2009
    I've just checked all the fuses and they are all good, upon really close inspection I've found there is a few total bodge jobs with the headlights and front end, it looks like it has had a very very light knock on the front and what they have done is repainted the bumper and taken out the headlight washers, (i didnt realise it had them until I saw the wires) and simply filled the holes (which you can see if you look very carefully) and then re-painted the bumper.
    The headlights are a disaster, they are pointing down slightly loose and the brackets look snapped and distorted , the indicators just dont seen to be flush with the headlights at all , or the bodywork and then on the seam of the headlights they look like they have been split and then sealed with some kind of glue, its a mess...
    Ganna get some pics up 2mora and see what you guys think.. I ve been a S3 owner a matter of hours lol
    Im thinking just try to get them working for now and then replace the whole bumper, lights and indicators with new?
    Looks like I bought me a lemon
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Can you not take it back to the garage who sold it to you?
    facelift xenons are very expensive to buy new (I believe they are in the region of 600 each from audi dealers) although you would be able to get them cheaper from a breakers or ebay etc.
    S3 AMK
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    shiiiiit.....feel sorry for ya VIP...welcome to the forum though fella... you'll get all the help you need here if you end up doing it yourself
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    V.I.P_UAE's Avatar
    Jan 2009
    [quote=MikeA3;660091]Can you not take it back to the garage who sold it to you?
    facelift xenons are very expensive to buy new (I believe they are in the region of 600 each from audi dealers) although you would be able to get them cheaper from a breakers or ebay etc.[/quote
    Can't take it back it was private sale sold as seen, my mistake for not looking at everything properly. oh well just have to crack on and sort it out, maybe get a new bumper and lights to make it perfect again.
    Another thing I wandered if you guys could help me with, how do I change the date and time on the dash? its saying 1999 on the date display, pressed all the buttons on the left stalk but nothing is happening?? And also, where is the power steering fluid top up? can't seem to find it...
    Thanks for the help guys, this is a really helpfull and imformative forrum, ,helps a lot
    jays3's Avatar
    Jul 2008
    75
    whens the mot mate u are gonna need the headlight washers to pass an mot.
    V.I.P_UAE's Avatar
    Jan 2009
    Quote Originally Posted by jays3 View Post
    I live in Dubai mate so that won't be a problem, no MOT here...
    anyone know how do I change the date and time on the dash? its saying 1999 on the date display, pressed all the buttons on the left stalk but nothing is happening?? And also, where is the power steering fluid top up? can't seem to find it...
    cheers
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    cheers
    I think you pull the right knob under the rev counter to set the time, date etc
    S3 AMK
