Volks AutosChris Nott
Thread: Pipe Leaks
    Apr 2004
    Sydney, Australia
    262
    Pipe Leaks
    Think i might have a pipe leak. Which are the obvious ones to check and any methods other than using a mirror? Any help = BIG thanks! Gracias!
    Apr 2004
    Sydney, Australia
    262
    Re: Pipe Leaks
    comon - im siffering here!
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Re: Pipe Leaks
    water pipe? air pipe? brake pipe?
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,579
    Re: Pipe Leaks
    Its a bit of hard graft really.
    Common ones are going to and from the wastegate and DV recirc pipe route
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    Re: Pipe Leaks
    if its a air leak take the pipe off the air filter and blow down it very hard and see if you can here any leaks
