JMB RetrofitsVolks Autos
    Dennis Moeller's Avatar
    Jan 2007
    NorWay
    442
    S3: Going to refurbish the suspension, tie bars, roll bars etc. What do I need?
    Hi again.
    OK, in my hunt for the perfect S3 I'm going to refurbish the suspension and drivetrain...I've started another thread on which suspension to choose and it seems to be the Bilstein B8 are the ones to grab. Springs; I will have to decide on that too but for now I got the dampers/springs under control.
    So:
    Suspension: OK
    ARB - H&R front & rear: OK (need to decide what size but thats just details)
    Brakes: OK (going to fit new OEM discs but better pads and braided line and upgrade to a better / new fluid, this will do for now)
    So here comes my questions, bear with me:
    I want to change all the bushes to new OEM ones...anyone who know all the partnumbers?
    The ARB's already comes with bushes, right, so those I don't need. What about tie rods, arms, tranny / diff holders and other bits and bobs...
    What will I have to replace in order to get a new "under carriage". Don't think if it's worth it or not, I'm going to do it anyway. I got the car cheaper for taht reason that it needs some TLC.
    I just want opinions on what to change. Partnumbers for the bushes would be sweet too. Other stuff can be aftermarket / upgraded but the bushes are to be OEM...
    As ever, thanks for your time!!
    My old car.. Still miss the lil rocket :-)
    Remapped Stage II - Forge FMIC - Dahlb�ck Intake - K&N - DieselGeek ShortShift - Phenolic - Powerflex Dogbone - Rial Daytona Race 8.5x18" ET30 - Forge Tiebars - Bilstein B8 - H&R 25mm - R32 rear ARB - H&R 20mm Spacers - EBC Discs - Red Stuff pads
    ______________________________________________
    NO ONE EVER REALLY DIED
    Jun 2007
    446
    if you lower it mate, your want the forge/kw tie bars to adjust camber.
    i replaced the top mounts when changing my susspension
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,503
    Hi Dennis, have a look here.
    Ess_Three's Star Performance Testing
    Jan 2007
    NorWay
    442
    Quote Originally Posted by jojo View Post
    I did, learned a lot! But still, I need some more info hehe...
    Is there a site, pdf file or similar where all the bushes and mounts are listed?
    @mat20vt: yeah adjustable tie bars at the rear are noted. Also will order the drop links in the front, going for V-Maxx shortened ones if nothinh better is suggested. The are shorter, and even tho I'm not going to lower it drastically it's probably better to install the shortened ones...
    What about control arms up front. Saw brand new ones on eBay for 99 quid per side...they have the track "balls" attached, right. Switch to new ones or just replace the "balls"?
    The thing I'm after the most are the part numbers for the bushes throughout the car...
