EM TuningVolks Autos
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    Problem with my old s3
    As alot of you know i sold my s3 to a mate to buy my touareg,well we tonight was driving along as about 40mph and the engine lost power an d started stuttering,i put my vagcom on it and it came up with p0301 misfire on cylinder one,has anyone had this problem before if so what was it,ph and ive tried iunplugging the maf and its still the same and removed the plug from the coil pack on cylinder one adn it made it worse which makes me think the coil pack is ok?
    What do you reckon spark plugs?
    A4 TDI S-LINE
    Essflee's Avatar
    Mar 2008
    1,995
    I'd still go with the coil pack breaking down... Your plugs wouldn't just go
    revo'd
    Tastyterrier's Avatar
    Monkey Trainer
    Jul 2003
    Staffordshire
    341
    I'd just had this on mine. It was the coil pack, it just didn't die straight away. It stuttered for a couple of days before giving up the ghost.
    A3 1.8TQS: Supersport Springs and Shocks, Xenons, BMC Filter, 18" OEM TTV6's, Bailey DV, N75J and Phase 1 Custom Code.
    Feb 2008
    2,810
    change all coil packs on all 4 cylinders
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    Switch the coil pack to another cylinder to see if the miss fire follows it, That will prove it beyond a doubt.
    Coil packs are a common failiure sadly
    jimbobery's Avatar
    S3
    May 2008
    257
    One of my coilpacks went last week. The car idled fine, but under full load at any revs the engine would stutter and shake; driving through the revs gently was fine and the engine was smooth, so I guess the coilpack was partially working and that they can malfuncation in differening amounts.
    When I put it onto my friends vagcom it showed cylinder 3 misfire. We swapped the coilpack to cylinder 2 and went for a drive with vagcom logging block 015 and 016 and cylinder 2 was showing loads of misfires everytime I accelerated, so it was obvious it was the coilpack.
    Price and part number of coilpacks in my post here:
    http://audi-sport.net/vb/showthread.php?t=64443
