Monster MotorsportChris Nott
    bhavin1986's Avatar
    BBP
    Mar 2008
    Leicester
    461
    Gearbox Oil topup...
    Hey guys. My gearbox hadto be replaced recently, and was leaking oil slightly once it was replaced. This has been dealt with so there's no more gearbox oil leaking. The thing is I'm pretty sure that the oil needs topping up..the transmission just doesn't feel as smooth as it did. Anyway, I just wanna make sure I'm topping up the oil in the right place....In the pic below its the thing on the top left:
    And in this pic its central:
    Is this the correct place? Any help would be great. I'm planning on doing this today at some point....cheers
    17" BBS RS Reps, JOM Coilovers, TT ARB, Facelift Front & Rear Lights, Aero wipers, LEDs all round, 6000K HIDs, Blacked out Grill & Rings, De-wipered,
    12" 1000w FliTrap Sub, Colour Coded Lowers & Skirts...
    bhavin1986's Avatar
    BBP
    Mar 2008
    Leicester
    461
    no ideas anyone?
    themanthatcan's Avatar
    Mar 2008
    Southampton
    665
    I can't be 100% sure as I'm going by memory here but I'm pretty sure that's a bung for a hole which, if removed, you can see your flywheel through. The last thing you want to be pouring down that hole is oil!
    2001 S3 AMK in black - Ambient lighting kit and Aero wipers.
    Is it wrong to love your car more than your girlfriend? - When you no longer have a girlfriend it's fine!
    Nov 2008
    16
    It that bung isnt the answer...then your probably look at filling it from the sid e(rather than the top).
    It'll be a sqaure-section plug like you would find for draining the engine oil from the sump.
    Ive never been down there on my audi...but I've had a few frenchies that needed to be topped up from the plug on the side (this also acts as a level meter - you top it up to the level of the plug).
    If you dont want to get dirty rolling around underneath the car...then you can top it up from above using a funnel and a peice of cut garden hose.
    Tom
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    525
    Try this link:
    http://www.brokevw.com/020oil.html
    It's for an 020 gearbox (used in the earlier rod change boxes on Golf GTI's but the casing is very similar to the 02A's. Should give you an idea...
    HTH,
    Imteyaz.
    bhavin1986's Avatar
    BBP
    Mar 2008
    Leicester
    461
    Excellent, boy am I glad I didn't add oil into where i thought it was! Would have been a costly mistake to say the least. Thanks for the replies. Much appreciated...
