EM TuningAH Fabrications
Results 1 to 15 of 15
    S3 D HY
    Sep 2008
    Belfast, Northern Ireland, UK
    37
    First start, no turbo
    Hi All,
    Bit of a strange fault with my S3, It's a 2002 225bhp. Basically, this only happened now and again but is becoming more regular. The first time i start the car every day the turbo doesnt work...ie, im driving along with no turbo kicking in. But as soon as i turn the car off and on again it works fine, and will do for the rest of the day.......any thoughts??? My car hasnt been serviced for a good while...could that have anything o do with it??
    any help would be appreciated, thanks
    Dave
    jesters3's Avatar
    The Shire's
    1,516
    Could be a multitude of things check out this link for info: http://audi-sport.net/vb/showthread.php?t=50418
    Ideally you need to get it VAGCOM first to see if any faults come up and then go fropm there.
    If it hasn't been serviced for a while, do the basics filters (20), oil (40) and spark plugs (30) and two hours
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    S3 D HY
    Sep 2008
    37
    the odd time it throws up a loss of boost pressure code...and then other times it shows up that the efficiency after the cat is below the threshold...sometimes both...just depends how often i clear it!
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Limp mode i would say, you need to fix the boost leak or MAF or whatever it is that throws the loss of boost code
    S3 D HY
    Sep 2008
    37
    when the managment light was on before there was never any loss of power or anything tho....for whatever reason this only seems to happen on the first start of a cold morning.....it worked fine today!
    Morgan-VAGCHECK's Avatar
    Foot to the floor
    Jan 2007
    103
    Quote Originally Posted by dhyndi View Post
    Hi All,
    Dave
    Hi,
    Would you say the issue occurs only on particulary cold mornings ?
    If it is, & you have the 17705 DTC (pressure drop) then I suggest taking a read of the following thread.
    http://audi-sport.net/vb/showthread.php?t=48308
    Regards
    Morgan
    S3 D HY
    Sep 2008
    37
    thanks for that! that's the exact problem. so am i to conclude that i need to replace the throttle body??? any ideas of cost?
    Foot to the floor
    Jan 2007
    103
    No dont replace the throttle body.
    Is your S3 remapped ?
    S3 D HY
    Sep 2008
    37
    no, its not remapped!!! what's the cure??!!
    Foot to the floor
    Jan 2007
    103
    Do you have Vag-Com ?
    If so can you tell me your ECU part number ?
    S3 D HY
    Sep 2008
    37
    is this all you need....
    http://drop.io/myvagcom
    Foot to the floor
    Jan 2007
    103
    Hi,
    Yes thats fine
    Well this particular ECU HW/SW variant can suffer from the issue I mentioned in the other thread (Cold start/low ambient temp/17705 DTC/limp)
    Its actually quite rare to hear owners with stock code complaining of it even though the trigger itself can occur by the very nature of its cause, normally its those with remaps who seem to report it.
    We patch this in our code if we know the ECU is an affected one, to avoid our customers experiencing this feature
    It may be you have some other issue causing your problem, but if the symptoms fit as they say !
    Regards
    Morgan
    S3 D HY
    Sep 2008
    37
    hmmmm so what do you reckon i should do about getting this resolved?
    S3 D HY
    Sep 2008
    37
    bump!!! my car's booked in this week for a service....is there anything i should get them to look at for this?
    S3 D HY
    Sep 2008
    37
    ok, so left my S3 into Aston Martin for a service yesterday (I work for a multi franchise car dealership and get labour cheap!) One of the guys there used to work for my local Audi stealer. He knew all about the car and i'd a good talk with him. He says this isnt an uncommon fault and what Audi used to do to fix it was remove the inlet manifold, give it a good clean and stick it back in again. So will hopefully get that done soon. Car's going great after the service though!
