Monster MotorsportChris Nott
    Nov 2008
    81
    Steering wheel? S3?
    Hi all,
    I want to change my boggo steering wheel (4 spoke) for an S3 type or similar. Mine is looking alittle tired, is this a straight forward swap or will the airbag light need to be turned off after I reconnect the cables?
    Also which model can I replace the wheel from? are all the S-line versions the same diameter... S3, S4 etc?
    scott_johnson's Avatar
    Audiless
    Bingley
    875
    Ive just recently done this and takes 5 minutes if that! Two torx behind the airbag, disconnect wires and one splined screw to remove the wheel. The airbag light will need resetting afterwards... i havent got round to doing mine yet!
    I have a 4 spoke multi function wheel for sale if your interested??
    SJ
    Nov 2008
    81
    Cheers mate.
    Im after the 3 spoke wheel chap, thanks anyway though.
