Volks AutosMonster Motorsport
    James333's Avatar
    Dec 2007
    227
    Oh god, will the problems ever stop!? Timing quetion
    People are probably tired of my S3 woes but upon watchin the ignition timing during idle on my amk S3, i noticed it jumps all over the place, sometimes 8deg. then 18deg. then 10deg. is this normal? I would have thought during idle, it should be pretty linear, please also see my other post regarding a faulty O2 sensor, would this contribute to the problems?
    Thanks so much you lot, i'd be stuffed without your help
    2001 AMK S3 Custom Code stage 1, B5 TIP, Jetex filter
    James333's Avatar
    Dec 2007
    227
    heres a link to my other post
    Is my O2 sensor broken?
    jim s3's Avatar
    Oct 2006
    longbridge, birmingham
    313
    you aint having much luck are ya mate mine stay at 9 at idle even with the bt
    James333's Avatar
    Dec 2007
    227
    ahh no, this is lame, what could cause this? I have 4 new plugs and 2 new coil packs. Im deperate to get the BT saved up for but these niggley little faults are eating away at my wallet and my enthusiasm
    jim s3's Avatar
    Oct 2006
    313
    try having you cam belt go now that kills the enthusiasm but then again if that never happend i would have never done the bt lol.. im sure you will sort it out you have done all the major problems just little ones left the number plate dont read 666 does it
