    Dec 2008
    S3 Brake upgrade
    Hi
    Can anyone recommend a front brake disc, calliper and pad upgrade for my 2000year S3? The standard ones are burnt out from track days so I'm looking for a reasonably priced upgrade that'll work for road and track.
    Many thanks
    James
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    the 4 pot brembo GT kit from a seat leon cupra R is a popular choice, not sure about the normal cost though
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    about 1000 i believe these days. Probably the most cost effective solution these days as you can get replacement discs for a good price (134/set for OEM discs or 200/set for drilled slotted, or just slotted)
    The other alternative is to buy a set of brackets from MBT (www.mbt-engineering.de) yo would need the MBT-140 bracket, and find some porsche calipers and some discs of your choice. MBT drill the bracket to the correct dimensions depending on the caliper and disc combo. A good upgrade would be Boxster S calipers and Leon Cupra R discs. Probably work out cheaper than the kit...Maybe
    IHI-VF34 + RACELOGIC + Parada SpecII = Who needs Quattro?! 0-60 5.1s @ Inters '06
    Thought of the month: People need to understand what is meant by 'Build Thread'...
    Feb 2008
    2,810
    i've read alot on the tarox discs which i've bought to go along with some ferrodo ds2500. will keep you posted.
