Badger5Volks Autos
Results 1 to 28 of 28
    James333's Avatar
    Dec 2007
    227
    S3 not getting to normal temperature.
    hey all, as the title says. Could this be my thermostat? My temp guage is getting to the dash just before the middle/normal temp position, I am experiencing poor economy too, could the ecu be thinking its still on warm up and changing fueling to suit?
    I have a new green top sensor fitted so dont think its that. Cheers now, James
    2001 AMK S3 Custom Code stage 1, B5 TIP, Jetex filter
    FazS3's Avatar
    Apr 2008
    857
    Thermostat or temp sender mate!
    MTM THE ULTIMATE STAGE!
    James333's Avatar
    Dec 2007
    227
    I think i'll order on from vagparts (thermostat) there is however a new one on ebay for about 8 delivered, will it be junk? thanks
    FazS3's Avatar
    Apr 2008
    857
    Get it from audi.Dont go for the cheap stuff its not really very expensive from audi anyway, temp sender roughly 30 thermo 18 i think
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,426
    Add Jimmeh on Facebook
    Guys, whilst it's fresh in my mind (having just returned from Audi RE a new keyfob..), how easy is it to fit a thermostat yourself?!
    Ive started to notice that temp' guage isn't where it should be.
    This image was taken 30 minutes into a ride through to Leicester last weekend:
    I did some testing this afternoon, leave it stationary, ticking over and sure, it rises to 85+ (which is where it should be, right?)
    Can you confirm for me that it should be ~90 when fully warmed up and not fluctuating between 60 and 70?!
    I believe it IS the thermostat thats gone, but what side effects is this currently giving me?! Running rich? Loss in performance?
    any help much appreciated.
    Jim
    Audi A4 Avant 1.9TDi 130 Quattro Sport.
    WhiteDetails.co.uk - Facebook? Follow me!
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Quote Originally Posted by James333 View Post
    I get the same issue and have just has the temp sensor changed to rule it out.I haven't noticed any difference yet though.
    I wonder if it's purely to do with the really cold weather as it regularly does this in the winter buit never the summer. I've also noticed that if you have the heater on economy (i.e. taking heat from the engine to warm the car) it runs even cooler, at about 80c.
    I've recently had the car serviced at Awesome and they reckoned it was either the temp sensor or thermostat. Thermostat is a bigger job though apparently.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    FazS3's Avatar
    Apr 2008
    857
    Quote Originally Posted by Jimmeh View Post
    Jim
    http://forums.audiworld.com/tt/msgs/1304805.phtml
    Check that out fella
    Jun 2003
    World of my own
    9,813
    If it rises when stationary then it's definately the thermostat stuck open or at least part open. But it should reach bang on 90 and stay there no matter what the weather.
    Alex Turner
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,358
    mine does this too! I've had a new thermostat for a year now, and not got around to fitting it!
    I've looked several times, but it looks almost impossible to me to get to the bolts, so I've always left it.
    James333's Avatar
    Dec 2007
    227
    Whos going to be first to brave it!? Im going to pick one up tomorrow. There is a few good walkthrough guides that I have looked at, its recomnended that a new dipstick tube is bought too as it will 98% of the time snap as it gets so brittle, I got one on saturday as mine was already broken anyway, about 3 from audi.
    Strangely too, Vag Parts is more expensive for the thermostat than audi.
    Oct 2008
    Finland
    14
    I changed thermostat last weekend. It is quite hard to unbolt that lower thermostat housing bolt but other than that its very straightforward. I used very small ratchet to open those bolts. That manual that was posted few post earlier was very helpful.
    Now my temperature is normal 90 degrees all the time.
    S3 8L -01
    VW Golf mk2 16V turbo
    rustyvw.org
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,426
    Quote Originally Posted by TeemuM View Post
    Have you seen any difference in performance/economy/driveability?!!
    I think I'm going to have to book mine in at Audi. Any ideas of the prices they charge?!!
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    526
    I too changed my thermostat last weekend as the temp would only just reach 90deg in standing traffic and shift down to 80-85 when on the move.
    Yes, the bottom bolt is a pain to get too but it is possible. The temp on my car (A3 1.8T) stays dead on 90 deg now. I found mpg has shifted from 24mpg to 26mpg.
    If it helps, I used the guide (from Vortex) and also found that it helps to remove the cabling from the back of the alternator (1x 8mm bolt for cable clip, 1x 13mm nut for thick power cable, unplug black plug) to give you a little more clearance. I did order a new dipstick tube, good thing too as that was the first thing that broke despite trying to be careful! The car definately warms up a lot quicker and the heating is much better too. For 12 squids (dealer price for thermostat) and 1.5hrs work it's well worth it in this weather.
    Jun 2003
    World of my own
    9,813
    Why would you take it to Audi?
    Find a VAG specialist and save at least 50%.
    Audi will charge 90+ per hour so probably 180 in labour alone.
    Alex Turner
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,426
    This is true. Only reason I suggested it is as I'm there already on Thursday/Friday to have a new keyfob programmed to the car.
    It would make sense to have a go myself, I'm sure we have all the tools to do the job, but it's a time factor. Yes, I'm off this week, but I've got a few jobs booked in that need chasing up.
    If I brought the Thermo from the Dealer and took it to my local, they'd be happy enough to fit it for me?!
    Id
    May 2008
    Australia
    39
    Mine was doing that, changed the temp sender to green top, still doing it. Have a tstat, just haven't got around to it yet. Still getting 28-30mpg so must drive like a grandma
    edward_harris's Avatar
    s3 gone now a shiney red evo 6
    Jan 2007
    berkshire, Reading
    1,062
    your temp should always be at 90, i had to change mine in the s3 took about an hour. like its been said its just the bottom bolt thats a pain to get to! apart from that really easy!
    Xbox online id - supaed133
    cornish_a3_turbo
    hi guys.
    just to let you know, i changed mine.....and it was the water pump!
    the plastic parts inside perish, so i had the cam belt done too.
    i too changed the temp sender, then the thermostat, thoughtt they was faulty, but in the end it was the water pump.
    any 1 else had this problem...??
    James333's Avatar
    Dec 2007
    227
    You wouldnt think an A3 cambelt would have the power to break a water pump hehe, sorry, only kidding and hoping you have a cornish sense of humour :o) where are you? Im near falmouth. Was yours getting too hot rather than staying cold?
    cornish_a3_turbo
    im in newquay mate...o and ill give you a run for your money....i know u have an s3....but..... lol
    mine was sitting below 70 at all times, but on idle, and parked up it would eventually rise to 90, but go down when i started driving again.
    if you need your cambelt and water pump doing i know a very very reasonable mech.
    o and mine didnt break...it perished!
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    This isn't caused by the waterpump. I've just had the pump, belt and all tensioners changed and it has not changed the temp prob. It must be the thermostat.
    > S3 225 (03) - OEM+
    View: My S3 diary
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    526
    True, I had my cam belt and water pump (which incidently was a plastic one but still in good working order) replaced two week before I changed the thermostat and had the same low temp problems. Changed the thermostat recently and temp sat at 90deg regardles and the heating is was fierce enough to melt your face, then I turned the temp down from HI to 22 deg and its much better!
    cornish_a3_turbo
    honestly, that was th problem with my car!
    as i say i thought it was a faulty thermos but it was that!
    ALSO mine isnt an s Line
    James333's Avatar
    Dec 2007
    227
    Quote Originally Posted by Funky_Junky View Post
    Yep, just done mine too, it would surely have the opposite effect anyway, a faulty pump would make it run hot where a duff thermostat is over cooling as the cooling fluid is always allowed into the rad.
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    I'm tempted to do this myself but given that it's -2c outside and I live in flat I don't think it's going to happen. I'll get a quote from Awesome and see what it comes in at.
    > S3 225 (03) - OEM+
    View: My S3 diary
    SDO
    153
    mines the same put a new temp sensor in as told by JBS and my needle don't move at all,
    A3 1.8T - S3 Black Leather interior, Pipercross panel filter, CC stage 1 remap, Vr6 clutch, G60 flywheel
  28. #27
    James333's Avatar
    Dec 2007
    227
    A normal garage will probably do it cheaper than awesome, wouldnt they charge 'performance tuning garage' prices? I dont know, just a thought tho as its not a specialist thing like some vag things are.
  29. #28
    James333's Avatar
    Dec 2007
    227
    Quote Originally Posted by SDO View Post
    do you think an already corroded wire could have broken when you changed it? the extra tug could have sent it over the edge? My sisters a3 had the same problem with her speedo, I was having a final look before I ordered a new sender and realised just inside the loom sleve, there was green corrosion and the wire had snapped.
