AH FabricationsVolks Autos
    Sep 2006
    63
    S3 steering noises
    Having a little problem with my car. When I've done a little driving I can hear a squeaking noise when turning left or right. I can also feel a bit more resistance when this is happening. It's fine when cold.
    Anyone else come across this problem?
    Keith
    jesters3's Avatar
    The Shire's
    1,516
    Check your Power Steering fluid had a groan with my steering and came down to no fluid - filled it up and all noises gone.
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    wanting a s3
    Oct 2008
    40
    I have a problem when pulling off in first gear on full lock, the car seems to vibrate like the wheels are catching or spinning, but I'm only pulling off slow. Any ideas guys?
    buying an s3 tomorrow
    WildBruce's Avatar
    Third Gear
    Oct 2008
    London
    197
    +1 for the knock on full lock, I get that when I leave work each night, although it does not seem to happen when I pull away slooooowly........
    Also [probably not related] I get a knock form the back left wheel [area] after I release the hand brake and pull away in the morning, I think it must be something sticky cause of the cold, but not sure what exactly it could be.
    Feb 2007
    enfield
    64
    i get the very same noise when on full lock.let me know when you find the cure.......
    amd remap,brembo 4 pots,k&n,powerflex mount
