Thread: Heater help
    May 2008
    Middleton, Manchester
    43
    Heater help
    Hello,
    Blower motor packed up, cleaned with some WD40 and it worked again for a bit now its gone, i have read that you can replace the brushes, would this fix or should i get a new one?
    used are 40
    New are twice the price!
    Brushes are 15
    Help!
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    it could also be the wires that feed the connector on the back, my old A3 had issues where i tied the wire back on itself to temporarily fuse the connection...which had obviously broken within the wires sheething
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    Jun 2003
    World of my own
    9,813
    No it'll be the brushes as usual.
    I tried the replacement brushes and found them noisey, so replaced the whole unit. Count yourself lucky, I had to spend 180 quid on mine (as it was a while back before ebay). The brushes should work fine if you are handy with a soldering iron.
    Alex Turner
    evobaz's Avatar
    Oct 2008
    Quote Originally Posted by AndyMac View Post
    What replacement brushes did you use?
    If you use these ones then they should be fine. I used these in my Passat and they're perfect - as good as OEM. (There's a way you can fit them without needing a soldering iron but you need to cut a wee bit off the end of the brush)
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=190267018046
