Volks AutosBadger5
Thread: Idle Issue
    May 2008
    Middleton, Manchester
    43
    Idle Issue
    hello again!
    The A3 1.6 has now got an idle issue. i have replaced the MAF but the car seems to bounce whilst idling. alo can cut out whilst on low revs approaching lights etc.
    Any ideas? would the temp sender have any effect on this?
    cheers
    Gee
    Jun 2003
    World of my own
    9,813
    Yes temp sender can cause exactly those symptoms. Duff info to the ECU will cause the air/fuel mix to be all wrong causing lumpy idle, stalling and high fuel consumption.
    Alex Turner
    May 2008
    43
    excellent mate, they are 12.50 from ebay thats cheap! I will invest and fix! thanks for your help
    Gee
    Jun 2003
    World of my own
    9,813
    I definately wouldn't do that! 20 from Audi dealer, and I'd do anything to avoid the stealers, but not on this.
    Alex Turner
    dela's Avatar
    Apr 2008
    Gloucestershire
    260
    it seems like im having the same problem, did you replace the temp sender? did it fix it?
