Sounds like your car is set up really nicely.
I'm interested to find out how upgrading the rear ARB affects FWD cars. Is this more likely to result in too much oversteer?
Same principle...but FWD cars tend to like far bigger rear ARBs!
On a FWD car, if you upgrade both ARBs you tend to get a larger front with a much larger rear bar...unlike the R32 S3 set up...and more like the Neuspeed TT set-up.
With FWD you don't have the advantage of any rear drive to help push you through the corner, so the rear wheels are basically castors, following the front wheels...a stiff rear ARB will radically reduce understeer.
With FWD you don't care if the rear wheels slide sidewards round the bend (lift off oversteer), in fact to some, that's the best way of getting the chassis to come alive and corner quickly.
With 4wd like the TT/S3 there will be some rear drive...so you don't want the rear so stiff that you break traction as then you are wasting power and torque...you want to use it to push you through the bend.
As with all things...go too big and it becomes unstable - that point is very dependant on how much front grip you have...but in general terms you can fit any available FWD uprated rear ARB and get good gains...sometimes it's better with an uprated front ARB too - certainly in the dry - but in the wet, it's sometimes better to have a standard front ARB and a big rear ARB.
Sadly, there is no fixed rule...anything bigger is better...to a point.
Eibach ARBs tend to work well on VAG FWD cars...but depending on what spec the rest of your set-up is, you may then find that you get much quicker everywhere until you again find some understeer...where you need to drop the front size back a bit, or go bigger on the rear!
Science it isn't...
Trial and error it is likely to be!
It's very unlikely you will ever get 'too much oversteer' on a FWD car...sure, it can be provoked on certain set-ups with lift off oversteer...but just fitting a big rear ARB is unlikely to turn your FWD hatch into a uber death machine.
