Results 1 to 25 of 25
    mattm's Avatar
    goldmember.
    Oct 2007
    Cheshire
    166
    rear light circuit faulty? only part of the rear light working
    anybody had the same, my rear brake and light bulbs are not working... although the indicator and reverse light are. ? any solutions apart from buying a new circuit.
    cheers
    Ibzzzzz's Avatar
    Apr 2007
    666
    Yeah that would be the brake switch under the pedal, Easy job to do just take the panel under the steering wheel off then twist it out, IIRC the pre-facelifts had a 2-pin switch and the others had a 4-pin, I done this on my A3 took no longer than ten minutes.
    2006 - A4 - 1997 1.8T 20VS, Full Black Recaro Leathers, Concert, Climate Control, Facelifted, Remus, Front armrest! - Sold
    2007 - A3 20vs -bridge gap motor....
    2008 - Think its time for the Civic Type R.
    2009 - Screw a Type R. Got a VR6 instead (missed even now)
    2011 - Focus St170. < what was i thinking...
    2012 - Lateee 8L S3 with EVERY extra....Broken...other asn members enjoying my parts!
    NOW! - B5 S4 Avant - 2.7 Twin Turbo POWWEERR! WWOOOOOSSSHHH!
    mattm's Avatar
    goldmember.
    Oct 2007
    Cheshire
    166
    Sorry mate could you explain a bit more? How come I have to unplug it? and whats the reason its stopped working.... Cheers
    Ibzzzzz's Avatar
    Apr 2007
    666
    I dont know what the reason for it to stop working is, but i know that when i had this exact symptom it was sorted after i changed my switch, and even if it isnt the problem your not paying 's for an electrician to come out.
    mattm's Avatar
    goldmember.
    Oct 2007
    Cheshire
    166
    do you know the part no for a new switch? ta very much
    Ibzzzzz's Avatar
    Apr 2007
    666
    This be the *****
    This was my broken one, note how the top bit hasnt sprung back out.
    Make sure you secure the bottom half of the dash on to these mounts before tightening up.
    Ibzzzzz's Avatar
    Apr 2007
    666
    And sorry i havent got a part number.
    mattm's Avatar
    goldmember.
    Oct 2007
    Cheshire
    166
    spot on mate cheers for the info, ill have to get me a new switch
    Ibzzzzz's Avatar
    Apr 2007
    666
    No probs good luck!
    Clach's Avatar
    A3 - 1.8Ts
    Jul 2007
    Oxford
    974
    the fuse may have gone fella...have a look at that next.
    Turbo Sport, Auto (I know!), A lot of 's -and rising [latest add: Recon'd. tranny] sunk in her since Aug. 07...
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,067
    I've got a similar, yet slightly more confusing problem on mine too!
    It was laid up for 6 weeks, and I've just started using it again, and it's only got 1 brake light.....
    The high level and drivers side brake lights work perfectly, yet the passengers side bulb WILL NOT light, I've tried 2 new bulbs in it, checked the white plastic bulb holder and all the metal strips supplying power look fine, the plug looks fine too, with no loose wires!
    Any ideas?
    mattm's Avatar
    goldmember.
    Oct 2007
    Cheshire
    166
    Prawn, take the whole bulb holder unit out, and connect it to the other side (that is working) and if it works you know its the same problem as i am having! thats how i diagnosed mine.
    Clach, will try fuse too mate cheers
    Clach's Avatar
    A3 - 1.8Ts
    Jul 2007
    Oxford
    974
    the fuse is a little red micro-one...
    mattm's Avatar
    goldmember.
    Oct 2007
    Cheshire
    166
    just checked and its fine, so gonna phone audi for a switch
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Do you have power at the that rear cluster? Get a voltmeter on it. You'll find the problem in no time.
    mattm's Avatar
    goldmember.
    Oct 2007
    Cheshire
    166
    there must be mate as the indicator and reverse light are working!
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Not necessarily, you can have power to one particular cuircuit, but not at another, otherwise all the bulbs would illuminate at once. Only the earth is common. Good for christmas I suppose :-)
    Rikster23's Avatar
    On the facelift path...
    Dec 2007
    London
    243
    I have the same problem. Pretty much without fail each month I have to replace my passangers side rear bulb.
    Friend suggested I get a new cluster, but I dont want to go ebay and buy one that might be faulty as well ! lol.
    The other option is to perhaps get facelift rear lights.
    Do these simply plug and play?
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,067
    sounds like the same problem I have! mines not every month, but every few at least, always passengers side!
    Facelift rear lights use exactly the same inner board, I kept my old ones as they are 100% identical, so that wont solve the problem!
    I dont have use of a multi meter currently, so I can't check if I'm getting power to the cluster or not.....
    it's BLOODY annoying too!
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,067
    I've just swapped my bulb holders over left to right (just hanging in the boot) and low and behold, it's the other way round! The left hand bulb lights, but not the right hand.
    That's great news for me, because I know it's not a wiring fault, and I just need a new bulb holder for the passengers side
    Rikster23's Avatar
    Dec 2007
    London
    243
    Will give that a try on the weekend Prawn.
    Thanks for the suggestion. Will have a look into facelift lights anyways as I am in the process of slowly changing the old pre facelift car into a facelift
    Just lights now. front and rear... but had no luck on the front ones
    Ibzzzzz's Avatar
    Apr 2007
    666
    Any updates?
    mattm's Avatar
    goldmember.
    Oct 2007
    Cheshire
    166
    lol yeah mate. bought a new switch, installed, and nope...
    after countless swearing and refitting the switch, I took the bulb holder out and low and behold the brake light bulb holder is broke. Its not holding the bulb in securley so its giving the error and obviously not working.
    Fixed it now, just jammed it in the holder for now till I get a new panel. Cheers
    Ibzzzzz's Avatar
    Apr 2007
    666
    AAaah! Im not showing my avatar on this site for a while! sorry mate.....
    mattm's Avatar
    goldmember.
    Oct 2007
    Cheshire
    166
    lol dont be daft, it was a good suggestion as i seen alot of the same on various sites.
    wasnt expensive and it was my fault for not checking the holder properly!
