JMB RetrofitsVolks Autos
    Jul 2004
    Reading
    81
    S3 2001 Poor Radio Reception
    Hello All,
    I seem to get poor radio reception in my S3 with the standard chorus and bose malarky. For example driving down the M4 I'd expect to be able to get radio 2 and 1 - but often its too crackly and comes and go. Are there any common issues with these radios? should I be looking
    at my Ariel mast or is that a waste of time. I did notice the mast was unraveling a tiny bit, maybe I should get a new prong. but I'm sure I used to use a coat hanger years ago on my mini.
    Thanks for any advice
    Brian
    Jun 2003
    World of my own
    9,813
    There's an amp inside the base of the bee-sting aerial. Could be fried if water has got in. There are also a few areas inside the car where the coax can break down. Best option is to pull the head unit unplug the aerial and stick a screwdriver or coathanger into the aerial socket. You should get perfect FM and at least this will prove whether it's the aerial or the HU. You can also try an antenna amp or similar.
    You should be able to get perfect FM even with the beesting part of the aerial removed with just the threaded bit sticking up.
    Alex Turner
    Jul 2004
    Reading
    81
    Hello,
    Do you have any instructions on how to dismantle the beesting base?
    thanks
    Brian
    Jun 2003
    World of my own
    9,813
    Don't think you can, you just have to replace it
    Alex Turner
