Volks AutosEM Tuning
Results 1 to 10 of 10
    Nigma's Avatar
    Yakshimash!
    Aug 2004
    Cambridge, UK
    60
    Trip LCD Display (DIS) gone blank
    Hi,
    All of a sudden my LCD on the instrument cluster has gone blank. Strange thing is though, is that it displays the "OK" in orange when I start the car and then goes blank.
    As if its just anything that is in red is blank.
    When i brought the car about 4 years ago, it was slightly faded towards the edges, but this hadn't got worse over time.
    Cheers,
    Anand
    Audi A3 1.8T Sport - Black
    The higher the monkey climbs, the more you can see its arse
    Mcblow's Avatar
    Jun 2008
    82
    i know it might sound stupid,but you haven't turned it off have you??
    Current cars...
    MK2 Golf 16v gti
    A3 8p 2.0fsi...
    Looking for 2002/3 Red S3 below 80k and £6k
    www.dubsuffolk.com
    807
    LOL
    themanthatcan's Avatar
    Mar 2008
    Southampton
    665
    Quote Originally Posted by a31dle View Post
    Sounds like it There's a button on the bottom of the wiper stalk which you've probably pressed, and which turns the DIS screen on and off. Try pressing it again
    2001 S3 AMK in black - Ambient lighting kit and Aero wipers.
    Is it wrong to love your car more than your girlfriend? - When you no longer have a girlfriend it's fine!
    Nigma's Avatar
    Yakshimash!
    Aug 2004
    Cambridge, UK
    60
    Red face
    [Embarrassed]
    Lol... Yep, I managed to switch it off. I pressed the left-right switch a few times and it didn't come on, Didn't realise that it's the reset switch that needs to be pressed.
    Cheers Guys.
    Anand
    Audi OCD
    Sep 2008
    68
    Ok, this has recently happened to mine but pressing the switch underneath doesn't sort it. Any ideas?
    Audi OCD
    Sep 2008
    68
    Just thought I'd follow up. I fixed the problem by checking some fuses, they were all ok but after reseating 3 of them my screen came back. I think I reset 11 + 15 which both refered to the instrument cluster, and also reset one that covered the ECU. I don't know which one did it but I suspect it was the resetting of the ECU.
    Dec 2009
    Middle England - Wolverhampton
    11
    Mine did the same, i re-seated the same fuses and it's back on except my reset button dosn't work (never has). Any fix for this???
    May 2011
    googled this post hence it being resurrected 3 years later lol my display has gone but ive tried the rest button and got nothing. has ok at top and tells me if the doors open but nothing else. anybody help?
    Audi OCD
    Sep 2008
    68
    Read my post just above. Do you know where the fuse box is? Open the driver door and pull off the panel on the side of the dash, then pull out the fuses I mentioned, wait a few secs then put them back in again. During the time I had the car this issue popped up about 3 or 4 times, easy fix though.
