Sky InsuranceAH Fabrications
Results 1 to 11 of 11
Thread: Changing Bulbs
    Nov 2007
    49
    Changing Bulbs
    Just bought some LED sidelight bulbs on ebay, but failing miserably at fitting them...
    On both sides I just cant get the covers off the back of the headlight units? Once unclipped, I've only got a matter of millimetres clearance to the battery/washer bottle, and there's no way they're ever going to clear the back of the Xenon's.
    I've seen threads on here stating it only takes a matter of minutes so what am I doing wrong?!
    Whilst I'm there, need to adjust the Xenon's as the beam is currently 'flat' for driving abroad, I understand there's a little metal lever to do this, is it below the xenon once I've got the cover off?
    jesters3's Avatar
    The Shire's
    1,516
    It is a knuckle scrapper but can be done. I changed the sides and mains with no probs once the cover was off, the next problem was getting the fcukers back on! I have heard some say it is a piece of piss but I think they are A3 drivers as the S3 engine bay is such a tight fit!!
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    themanthatcan's Avatar
    Mar 2008
    Southampton
    665
    It really is a two minute job once the covers are off, which incidentally I find more difficult than changing the bulbs! There are two wires which go into the back of the sidelight bulb holder. Just grab them and give them a tug..et voila! The bulb holder and bulb should just pop out.
    Don't forget that the LED sidelights only work plugged in one way so make sure you check they work before putting everything back together!
    2001 S3 AMK in black - Ambient lighting kit and Aero wipers.
    Is it wrong to love your car more than your girlfriend? - When you no longer have a girlfriend it's fine!
    Nov 2005
    Scotland
    112
    would fitting them the wrong way cause them to flash ,i bought a set at the weekend and when i tried them they just flashed ,didn't think to turn them in the holder.Looked pretty cool and i'm sure everybody would get out the way on the motorway .haha
    02 A4 Avant 18T Sport (163) Multi
    Sat Nav+ , Grey alcantara
    RS4 Alloys ,EBC Discs & Pads
    Mar 2008
    Southampton
    665
    Quote Originally Posted by alipaton View Post
    Normally if I've installed them the wrong way round they just don't work.
    Funnily enough I had to replace my 2 eBay LEDs the other day because one of them had started flashing. Closer inspection showed that a couple of the little LED diodes had failed so I can only assume that's why it started flashing.
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    erm im thinking that your LED's will have had a flashing sequence in built, wrong polarisation shouldnt achieve that
    incidently i took my battery out to change the hardest bulb, passenger side
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    Nov 2005
    Scotland
    112
    cheers mate got these ones from auto bulbs direct they have 3 or 4 diodes on each bulb bit peed off as they look quite good nice and white .but hey what can you do
    Matt T's Avatar
    Bumble Bee
    Jun 2008
    London
    88
    I spent ages twisting them, but infact they just pull out.
    Audi S3 Quattro
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    not a great deal, i bought off ebay from company called Ace parts (alan@aceparts.com), bought in March, 1 bulb has just gone... (common for LED's to not last very long)...emailed them last week and asked for couple new bulbs and mentioned that i would pay, and they are sending me 2 through the post at no cost.... initially they cost me 3 inc postage and they supplied two bluey normal fit 501 bulbs aswell!! (as alternative to LED's but werent white enough)cant fault this firm at all
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    turn them 180 degrees and fit again.
    i bought mine from ultraleds.co.uk. almost a year now and no problem at all. was 13 a pair. http://www.ultraleds.co.uk/ultimate-...te-p-1677.html
    well worth it since it's almost matched the HIDs
    ^^ In my opinion
    Nov 2005
    Scotland
    112
    i'll try them again next time it;s dry (prob about april)need to make do with the bluey ones just now cheers for the help,and sorry to have hijacked this thread.out of intrest is there more room behind the headlight on an s3 than an a4 as i found it easier to just take the whole light unit out
