stuartaw11
i got my s3 about 2 months ago, the water pump is leaking heavily so needs replacing, my question is if its safe to drive a couple of miles to my local garage and also do i need to replace the cambelt and tensioner as it was only replaced 3 thousand miles ago? strangly the waterpump did not leak before the same garage replaced the coolant last week, the "mechanic" cleaned the expansion bottle with a jet washer could this have put too much pressure on the water pump and broke the seal? any help would be much appreciated
